Old 11-08-2021, 10:58 AM
justincampbell's Avatar
justincampbell justincampbell is offline
Default Sprint Parts - I think most are '67
I have a bunch of OHC 6 parts for sale. Most if not all came from Sprint engines.
Air Cleaner assembly - $200
cam sprocket - $18
water neck - $18
timing cover, top is good, bottom has a hole - $50
fan blade - $26
valve cover and cam - $70
I have more that I have not yet taken pics of or figured out a price(among them a Sprint intake/exhaust and carb). I will keep adding pics and prices as my schedule allows. Also, I have a couple blocks/cranks(think one is 230 and one is 250, but not certain) that I haven't yet bothered to dig out because I didn't know if there was any interest in those pieces.
Name:	OHC6 air cleaner 1.jpg
ID:	577225   Click image for larger version
Name:	OHC6 air cleaner 2.jpg
ID:	577226   Click image for larger version
Name:	OHC6 cam sprocket 2.jpg
ID:	577227   Click image for larger version
Name:	OHC6 fan blade 2.jpg
ID:	577228   Click image for larger version
Name:	OHC6 timing cvr 1.jpg
"What the hell's wrong with freedom man? That's what it's all about." (Billy)
"Oh yeah, that's what it's all about alright... but talkin about it and bein it, that's two different things." (George)
Easyrider
Old 11-08-2021, 10:59 AM
More pics
Name:	OHC6 tstat housing 1.jpg
ID:	577230   Click image for larger version
Name:	OHC6 valve cvr cam 2.jpg
Easyrider
Old 11-08-2021, 12:57 PM
tinindian68's Avatar
tinindian68 tinindian68 is offline
I’ll take the air cleaner. PM sent.
Old 11-12-2021, 05:58 PM
Alternator(core) with steel tab - $20
Sprint carb - needs totally gone thru, but I don't think anything is broken - $175
Sprint intake/exhaust manifolds - $1400
Power steering stuff is posted for tinindian68
Name:	OHC6 alternator 1.jpg
ID:	577568   Click image for larger version
Name:	OHC6 alternator 2.jpg
ID:	577569   Click image for larger version
Name:	OHC6 carb 1.jpg
ID:	577570   Click image for larger version
Name:	OHC6 carb 2.jpg
ID:	577571   Click image for larger version
Name:	OHC6 carb 3.jpg
Easyrider
Old 11-12-2021, 06:00 PM
more pics
Name:	OHC6 manifolds 1.jpg
ID:	577573   Click image for larger version
Name:	OHC6 manifolds 4.jpg
ID:	577574   Click image for larger version
Name:	OHC6 manifolds 5.jpg
ID:	577577   Click image for larger version
Name:	OHC6 PS pump 1.jpg
ID:	577580   Click image for larger version
Name:	OHC6 PS pump 2.jpg
Easyrider
Old 11-12-2021, 06:13 PM
sprintbird sprintbird is offline
How much on the power steering?
Old 11-12-2021, 07:01 PM
tinindian68 has first shot at it. If he passes, I'll post a price.
Easyrider
Old 11-16-2021, 10:31 AM
PS pump/bracket and air cleaner have been sold.
Price on valve cover lowered to $60
Easyrider
Old 11-24-2021, 01:34 AM
I've got a few more pieces cleaned up
Alternator bracket. It is tweaked a bit, but will probably straighten
easily enough - $25
Cover that goes around the crank snout(sorry, don't know what the correct name is). It will need blasted/stripped, painted, and a new seal installed - $20
I'm not sure what this aluminum bracket is. Since I don't know what it is, but I need to put a price on it, $50. I can adjust the price if appropriate after someone clues me in to what it is.
Name:	OHC6 alternator brkt 1.jpg
ID:	578459   Click image for larger version
Name:	OHC6 alternator brkt 3.jpg
ID:	578460   Click image for larger version
Name:	OHC6 timing cvr rear tin 1.jpg
ID:	578461   Click image for larger version
Name:	OHC6 timing cvr rear tin 2.jpg
ID:	578462   Click image for larger version
Name:	OHC6 alum brkt 2.jpg
Easyrider
Old 12-04-2021, 02:02 AM
Update: I figured out what the aluminum bracket is(PS bracket for 67 to 70 Pontiac) and I am hanging on to that one.
Also, I will include the carburetor with the manifolds for $1400.
Easyrider
Old 01-12-2022, 04:46 PM
water neck is sold
Easyrider
Old 02-28-2022, 11:19 AM
valve cover sold.
Manifolds and carb - $1300
Easyrider
Old 06-27-2022, 09:59 AM
Unhappy
Updated pictures of alternator.
Name:	OHC6 alt 1.jpg
ID:	593379   Click image for larger version
Name:	OHC6 alt 3.jpg
Easyrider
Old 04-24-2023, 12:12 AM
I was going to update with what else has sold. But, I have enough posts on this thread, it just seems easier to list what is still available.
Sprint intake and exhaust manifolds with Y pipe - $1300
cam sprocket - $18
fan blade - $25
Alternator bracket. It is tweaked a bit, but should straighten okay - $25
Cover that goes around the crank snout(sorry, don't know what the correct name is). It will need blasted, painted, and a new seal installed - $20
I also just found a nicer alternator bracket. This one appears to be in good shape other than needing sandblasted and painted - $40
I will also have at least one block available if I ever get enough other stuff sold(out of my way) to get it cleaned up and some pictures taken.
Easyrider
Old 04-24-2023, 09:07 AM
What is the P/N on the Carb?
Old 04-24-2023, 12:30 PM
Carb is gone. The parts that I still have for sale are in the post above yours.
Easyrider
Old 06-07-2023, 01:11 AM
Alternator bracket in post #9 is sold
Easyrider
Old 11-22-2023, 09:54 PM
Manifolds, cam sprocket, better alternator bracket, and tin cover around crank are still available.
All other parts are sold.
Easyrider
Easyrider
Old 12-22-2023, 01:18 AM
$1,100 for manifolds and beginning exhaust section
Easyrider
