Old 10-16-2021, 12:54 PM
mklinger's Avatar
mklinger mklinger is offline
Default 1971 Firebird - Correct Window Roller?
Refurbing the windows on the '71 Firebird and had ordered replacement rollers from The Parts Place. The replacements are 2 1/4 +/- long but what I removed from the car are about 1 3/4 +/- long. Which are correct given anything is possible in 50 years? Feedback appreciated. Thanks.
There are no problems..only solutions.
Old 10-16-2021, 09:44 PM
Formulabruce's Avatar
The short one is correct, however, have seen longer ones used as it tends to keep more pressure on the top of the window to go toward the car.
Old 10-17-2021, 06:11 AM
mklinger's Avatar
For the hell of it I tried to install the window with the long one…..no go. Too wide to slip through the gap even with outer weatherstrip removed. New parts ordered.
Old 10-17-2021, 01:52 PM
I saw a guy lay window over to do this. May as well get whats correct though.
Old 10-17-2021, 03:54 PM
Norwood's Avatar
Norwood Norwood is offline
It’s a tight fit to get the glass in the door with the correct rollers. I don’t see anyway you get it in with those too long ones.
Old 10-18-2021, 07:08 AM
mklinger's Avatar
I removed the outer weatherstrip to attempt. Generally speaking, should that weatherstrip be installed before or after the window is in the tracks?
Old 10-19-2021, 05:11 AM
Aus78Formula Aus78Formula is offline
I'll have to check which is supplied in a kit I picked up years ago. I wonder if the regulator parts are available to replace, that are riveted in place, or perhaps just the roller ends.
Old 10-21-2021, 12:29 AM
oK, measured mine overall, also the 1-3/4" of original roller. Mine came from Tamraz's years ago, black roller.
It's part of the AMD W-033 window kit, was available as one lot or separate pieces.
https://www.carid.com/auto-metal-dir...mpn-w-033.html
W-022 is the rear roller each.
https://www.summitracing.com/parts/amd-w-022
