OK lets do it....im all ears!
GTO George |
Well, since you are involved, should we break it up in classes? Fast brackets, slow brackets---fast heads up, slow heads up---multi-year head gasket use, new head gaskets yearly---Over 3000lbs, under 3000lbs???
Set some perimeters so we dont upset you. |
The main bass line plus has got to be the need for less rpm and the reduction in loading by twice that at any given rpm .
The Following User Says Thank You to steve25 For This Useful Post: | ||
![]() Quote:
tuning down............Smaller cams (easier on the valve train)....less boost (easier on head gaskets and engine parts) GTO George Last edited by GTOGEORGE; 08-08-2021 at 01:58 PM. |
![]() Quote:
GTO George |
![]() Quote:
Back in the old NSCA days, they kicked Turbos out of Pro Street because they said it wasn’t fair that they could sit and drink cold drinks between rounds, while everyone else was thrashing to get ready for the next round. I figured you’d already know this, since you are so superior in the field of racing. |
![]() Quote:
There are blow through carbs that have gone low 4s in the 1/8th what is the fastest roots with carbs that you’ve heard of? |
![]() Quote:
Don’t know 1/8 mile really! GTO George |
What does that even mean? You are a racer arent ya?
1/4 is real racing, I only run the 1/8 because I have to.
It was really nice at Norwalk. GTO George |
Well, we can make it 1/8th vs 1/4 mile...But, the turbos are even stronger on the big tracks, so yet again, you need to rethink this...
Lets start by saying real racing is heads up
![]() ![]() Stan
![]() Quote:
I love heads up racing…..but 1/4 mile. GTO George |
Be honest George...What heads up class would you fit into? And, keep in mind that heads up racers will step on their stuff in order to win...
![]() Quote:
GTO George |
Simple the Roots style blower wins for cosmetic appeal.
Turbo will be that fastest in the right hands. Pro-charger style blowers have comparable bottom end of the Roots style blowers and add a bunch of weight in the wrong place. |
For consistent passes a roots type blower....1/8 mile any blower!
GTO George |
A turbo car, turned down to make the same HP as you are making, will outlive your combo...It is easier on parts, plain and simple...
The Following User Says Thank You to opeliac For This Useful Post: | ||
![]() Quote:
GTO George |
![]() Quote:
How much power do you estimate it taking to run what you run? |
