Old 08-04-2021, 03:17 PM
TPM TPM is offline
Default Tremec TKX install finished - 65 GTO
Finally finished installing the new Tremec TKX in my GTO.....5th gear is a game changer! Highway driving at 70+ mph is now a real pleasure.
Old 08-04-2021, 04:21 PM
Tom Vaught's Avatar
Boost Engineer
Glad you are happy about that. So much better vs getting run over by the buses and trucks because the engine is not happy at 70+ mph.
Tom V.
Old 08-04-2021, 04:41 PM
The Champ's Avatar
Which TKX did you go (3.27 first with .71 5th or 2.87 with either a .81 or .68 5th) and what with and what is your rear gear ratio? I'm toying with the idea of a TKX for my '64 with a 3.08 12 bolt posi.
Old 08-04-2021, 05:39 PM
Tom Vaught's Avatar
Boost Engineer
I went with the Nash 5 speed, many years ago, 3.27 1st gear, but my trans was built with a special "Equal Energy Split" feature built into the trans gear ratios.
If I bought a TKX it would be the 2.87 with the .81 5th and still using a 3.08 posi.
Tom V.
Old 08-04-2021, 05:57 PM
TB1's Avatar
TB1 TB1 is offline
Although apples to oranges in comparison I went with the 2.87 1st and the .68 OD with a 3.23 rear gear 70mpg right around 2000 rpm and its responsive from this speed when you get on it, First gear to me anyways seems a little short so I could only imagine with the 3.27 first it would be over in a blink of an eye when into the gas, normal driving its fine but with a 3.08 rear gear it would probably be a good fit well worth the expense either way
65 LeMANS , SD performance 462ci Engine, Tremec TKX 5 speed with a 3.73 geared 8.5" 10 bolt
Old 08-04-2021, 06:41 PM
tom s tom s is offline
my 69 bird has a 3.27 first with a 3.31 rear.No issue in street driving.My 63 421 Lemans has a 2.87 first with a 3.90 rear gear and will be going to a 3.64.Did not feel comfortable going to the 3.42.FWIW,Tom
Old 08-04-2021, 08:14 PM
TPM TPM is offline
I installed the close ratio 2.87, 1.89, 1.28, 1.00, .68.....used the oem bellhousing and clutch assembly with a new 26 spline clutch disc. 3:55 gears in my stock 10 bolt.
Old 08-04-2021, 09:13 PM
67GTONUT's Avatar
67GTONUT 67GTONUT is offline
Mine is close to being done....
Went with the 3.27 1st gear - I have 3.36 rear.... should be nice
Troy
Rockaway NJ
67 GTO
400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI
HOTCHKIS/UMI/BILSTEIN
Old 08-05-2021, 01:30 PM
GTO3DEUCES GTO3DEUCES is offline
Default 🔰 Photos of the install process❓
Yours is a 64/65 right❓Do you have photos of the install process and the cockpit❓
Also, do you have a console and what modifications if any did you need to make to get the console properly fit❓
Best Regards,
Dave
389 .030 400ci Tri Power, .068 cam, HO manifolds, M-20 4 SPD, '70 12 Bolt 3:36 Chevrolet posi-traction, Montero Red, Parchment gut, VINTAGE AIR, PFDB, Bilsteins, F&R HD Sways, Hotchkis rear bags, Firestone Indy 500 shoes
What's the point of owning a muscle car if you can't scare yourself stupid from time to time
Old 08-05-2021, 01:57 PM
TPM TPM is offline
Yes, my 65 GTO is an original 4-speed console car. The only modifications I made during the installation was drilling 2 new holes in the frame rail on each side of car because the trans cross member has to be moved back to accommodate the longer Tremec trans. I also had to slightly trim back the shifter hole on the passenger side of the shifter porch for greater clearance of the bolts on the shifter stick.
Old 08-16-2021, 09:16 PM
67GTONUT's Avatar
Picked up mine today and brought it home..... did not hit the highway, but shifts real nice..... Really looking forward to this....
Troy
Rockaway NJ
67 GTO
Old 08-16-2021, 09:23 PM
TPM TPM is offline
Hey 67GTONUT - you’re not that far from me.....get that goat out on rt. 80 and enjoy 5th gear!
Old 08-16-2021, 09:48 PM
67GTONUT's Avatar
LOL
As soon as Tropical Storm Fred stops dumping rain on us this week
Troy
Rockaway NJ
67 GTO
Old 08-16-2021, 10:30 PM
66beaumont's Avatar
66beaumont 66beaumont is offline
Best mod I’ve done. You’re going to love it and will probably drive the car more now.3:27 gear with a 308 rear is nice(had that behind 454 in my 66 Beaumont and 68 overdrive was no issue with 308 rear either. Would pull vey nicely from 1800 rpm cruise even up hill
69 gto ,all#match,467,th400,3:55 Easton posi,resto completed may 2016. 427 hp/530tq. Stump puller with stock#62 , stock intake and qjet
Th400 gone. Tkx close ratio with .64 of
66 Pontiac Beaumont sport deluxe,BB 5sp tko 3:08 auburn 450hp 550 torque wife sold it
