Has anyone ever flowed an Offenhauser 5499? I'm curious how it flows between the edelbrock p65 or even compared to a stock iron manifold.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears |
The only help I can off is to post the flow numbers for the Standard Performer, as my flow test notes on from a iron Intake have gone missing at the moment.
The Perfromer flows a bit less then the iron, but the flow per runner is better in terms of balance.
I have not flowed the 5499 but can tell you it was .3 tenths quicker than the P65 on a 421 I built back in the 90's. Mild combo, 421 .060, 62 heads ported to 260CFM and a Comp 288H Cam. Same 750 carbs etc. Only swap was intake.
