Old 05-11-2021, 06:47 PM
weranc55's Avatar
weranc55 weranc55 is offline
Default 68 Ra2. Need a list of all that incorrect
I would like to freshen up the engine compartment this summer. Planning on pulling the motor. I don’t know Ra2’s that well and want to correct as much as I can. This is what I have so far.
Clutch fan incorrect
Heat shield?
Clamp on ps hose
Wrong master
Temp sending unit
ID:	566412   Click image for larger version
ID:	566413   Click image for larger version
Old 05-11-2021, 07:30 PM
Scott Thelander's Avatar
I dont wanna be the guy but ,,,
being a 68 guy by heart
its lookin goood underthere ,,,,,,,,,,!!!
a few tid bits maybe ...
incorrect oil fill cap
no front alternator bracket
wrong water pump bolts ?? I dont see the cross hatch heads ...
over flow hose clip on radiator ,,,, radiator tag ,,
dual carb spring?? color s yellow n blue
425 coil ,,,,, hmmmm
wrong nut on the power steering pump maybe also ,,, I see alot of castle lock nuts on ole originals
nice to see you use it !!!
any running you tube videos ???
4 speed also eh !!??
nice !!!
The Following User Says Thank You to Scott Thelander For This Useful Post:
Old 05-11-2021, 07:46 PM
weranc55's Avatar
Thanks yup 4 speed.
These correct?
ID:	566420   Click image for larger version
Old 05-11-2021, 08:51 PM
not really
and
yes
hopefully some one has some originals for you ,,,
I have seen a couple engine s with brackets that the slots dont line up welll
always wondered ifone was a repro and 1 an original ,,, like one slot was longer than the other bracket,,,
and
fairly sure we had a big S on the rivet in the center,,,
I would just add a couple correct items under your hood and keep drivin it !!
I enjoy looking at nice driven original cars .... rather than shiney restos
Old 05-11-2021, 09:02 PM
Brewster's Avatar
Brewster Brewster is offline
Looks nice why pulling it? The only thing my old eye's notice is that Oil Fill Cap. Throw on a AC-FC2 is my guess but most likely wrong Nothing like learning a new year let alone new hp motor. Enjoy and do keep sharing. Cheers
Old 05-12-2021, 12:06 AM
OG68 OG68 is offline
Not an expert with the RAII but;
Coil should be a 288.
My original oil cap looks like yours
2007 Cadillac SRX
Old 05-12-2021, 12:12 AM
Get a original carb on there to 7028273 XX
And your clutch fan is wrong Get a 4 blade cheapey
Old 05-12-2021, 12:29 AM
weranc55's Avatar
Four blade or 5?
Old 05-12-2021, 10:53 PM
68pongto's Avatar
68pongto 68pongto is offline
Originally Posted by weranc55 View Post
Four blade or 5?
No, all 68 Ram Air cars used the standard 4 blade fan like this. Also, your water pump pulley should be plated silver cad/zink, not painted black.
ID:	566485Click image for larger version
ID:	566486Click image for larger version
Old 05-12-2021, 11:26 PM
weranc55's Avatar
Attachment 566485Attachment 566486Attachment 566487
Old 05-13-2021, 10:21 AM
weranc55's Avatar
What spacer do I need?
Old 05-13-2021, 11:32 AM
gtoguys gtoguys is offline
The distributor vacuum solenoid should have a green cover. Black was for the standard engine with 3 or 4 speed.
Old 05-22-2021, 11:37 PM
Mcronk Mcronk is offline
Unless you can find an original no one reproduces the green cover. However you can get creative and paint it to be green. There was an original on ebay a while back. I used it for reference.
Nice to see original set of RA II exhaust manifolds. I got lucky and found a nice set. I had them coated by Jet Hot.
I made some changes from stock configuration. I "by passed" the factory vacum advance routing (its there for correct look) but found my car likes vacuum from intake port (full vacum). Carb is a 263 not 273 ( 263 is correct 68 manual transmission). Distributor is a early 68 manual transmission code modified with single advance port like correct RA II distributor. I had sold Jim Mino the last correct fan blade and spacer I had. Also talked to him about distributors and vacum routing before he passed. He sent me pictures of a RA II distributor he just restored.
I find these RA II cars intriguing. In fact 68 GTO has a lot of "one year only" parts much like the RA II engines.
My car is not a concourse car but am trying to make it mostly correct.
ID:	567064   Click image for larger version
ID:	567066   Click image for larger version
ID:	567067   Click image for larger version
Old 05-23-2021, 12:24 AM
I have a couple green vacuum multipliers and a 7028273
Old 05-23-2021, 09:56 AM
weranc55's Avatar
Very nice. Please post a pic of your fan setup. No heat shield on the manifold?
Old 05-23-2021, 11:29 AM
Somewhere i have a 68 4-Blade Fan and Spacer from a 68 Catalina 400 2bbl.
Was mint when pulled the engine in 1981 to rebuild. Never assembled it.
Painted everything Gold & Grey, so that will make it easier to locate in 2021.
It will be the only Gold Fan i have
Not sure if they are date coded or ID stamped (AA for example)
Have a 68 Ram2 PMD Buildsheet to pull codes from for fan & spacer.
Just need to verify it didn't have any HD Fan option on the Buildsheet car.
Or on your Car.
Buildsheet is from GTO Wolf 68 TripleBlk Ram2
The Aegena Blue Ram2 4spd had a driver side Exh Shroud when found.
Sort of backs up the idea that the cars were shipped with the single snork breather mounted.
Old 05-23-2021, 11:35 AM
The PY member who rescued and restored the Aegena Blue Ram2 posted a lot of reference pics about the car/engine pieces iirc
Don't remember if its in this thread or if he started another thread.
His user name was something like yellow66gto or something along that line if you want to search the forum for his posts.
PS - the Fan & Spacer would be Catalina Price , not Ram2/JudgeConvertible Price
.... for YOUR car , or anyone who owns a documented Deuce. No prospectors need bother to inquire
Old 05-23-2021, 12:01 PM
First two engine pictures are of the Aegena Blue car. It is a automatic manual steering and brakes so a few differences. I have attached pictures of the fan and spacer I sold Jim Mino. They came off a 68 Tempest Custom 350 2bbl. Also will attach pictures of Jim Mattisons RA II GTO that sold at BJ in 2016 (last engine picture). It is very correct but does appear to wear reproduction RAIV exhaust manifolds.
I have seen pictures of the heat shield. From what information I have gathered the cars were shipped with closed hood scoops and standard air cleaner/heat shield. The RA pans and open scoops were in the trunk. Dealers installed them and painted the scoops to match the car.
ID:	567084   Click image for larger version
Name:	Aegena Blue engine 1.jpg
ID:	567085   Click image for larger version
Name:	Aegena Blue engine 2.jpg
ID:	567086   Click image for larger version
Name:	Mattisons RA II.jpg
Old 05-23-2021, 12:08 PM
The Automatic Aegena Deuce was from Muscle_Collector stock.
The 4spd Aegena Deuce was a field find on eBay - different car.
Was being sold as a parts car/project on eBay and he scooped it up for cheap.
Very un-touched in engine bay/engine departments
yellow66gto or something like that
He had as-found engine / engine bay pics
Exh Shield was present as-found , still mounted in place.
Old 05-23-2021, 12:18 PM
Thanks for clarifiation. Did not know there were two documented Aegena Blue cars out there. The pictures I have were from the MCACN event. I am collecting as much information about these as I can to better educate myself and correct things on my car. Picture attached is the car that I showed engine pictures for.
