heater hose inner fender bracket
got a bracket that mounts on the inner fender for my 72 formula . i can not see any hole were this would mount anyone one have a photo
cheers to all |
just wondering ,did these brackets come on the 72 formulas
found this and it shows the bracket attached to the head.
http://musclecarfilms.com/1969_Fireb...ir_setups.html
67 Firebird Convertible |
I just found this and maybe it'll will help. https://firstgenfirebird.org/forums/...&Number=307336
This is from the 72 Service Manual (for non-AC):
thanks for the photo . my car has a/c i think it has a bracket that is mounted on the inner fender that hold the heater core hose and one of the a/c hoses
You didn't say.
The hose is tie wrapped basically to an AC hose.
Pic:
sorry about that . i guess the bracket did not belong to my car
thanks for the photos |
I was going to say that I believe Camaros used brackets.
the pic in post 9 doesn't show the heater control valve . there is a bracket that screws it to apron. i'm not sure about 72 though
heater valve
A pic of the bracket would help.
I know on some camaros there was a line bracket that bolted to the edge of the fender itself, and a couple models had a double hose bracket too. .
Do you mean this clip?
1973 Heater Hoses on Passenger Fender
Here is a picture for 73's that do use a bracket. This is NJSteve's, but mine has the same bracket.
1973 Formula 400 4 spd 04C build date Norwood assembly plant. |
Yes that is the one. Did they come thr 72 cars I have both types of clips
That same clip I believe is used on some A bodies too.
