Old 01-30-2021, 07:28 PM
Qball's Avatar
Qball Qball is offline
Default Spark plug gap recommendation
I am building my stroker engine for my GTO. I am using ‘77 6X-4 heads. I am using a MSD rtr distributor with a blaster 2 coil. The compression ratio will be in the 9.3:1 area. I have a set of AC Delco R45TSX spark plugs that I’ll be using. With the above information, what should the plug gap be set to? This will be street driven.
Let me have a Diablo sandwich and a Dr. Pepper and make it fast---I'm in a goddamn hurry!
- Mike
1967 GTO
Old 01-30-2021, 07:30 PM
geeteeohguy's Avatar
.035"-.040" would be my choice. YMMV.
Jeff
The Following User Says Thank You to geeteeohguy For This Useful Post:
Old 01-30-2021, 07:49 PM
77 TRASHCAN's Avatar
Welcome back!
The TSX plug is a .060 gap plug. Some are ok with wider gaps, but am not. It puts more resistance in the ignition setup.
AC plugs have not been getting favorable reviews for a while...
NGK seems to be the primo plug for any applications...
I’d use a NGK equivalent to the AC R44T or R43T. These gap at .030. Many here prefer the extended tip plugs, R44TS or R43TS, the also gap at .030.
I’m guessing, by now, you got ALL the flooring in he house done?
Shut it off
Shut it off
The Following User Says Thank You to 77 TRASHCAN For This Useful Post:
Old 01-30-2021, 07:52 PM
steve25 steve25 is online now
The X series plugs are made for running a .060” gap and I would not run those, you want the plain TS suffix plugs, then gap them at .045”.
Old 01-30-2021, 07:53 PM
Qball's Avatar
Originally Posted by 77 TRASHCAN View Post
Welcome back!
Thanks, man! Good to be back! I can’t believe I’m actually moving forward with this!
This was today’s progress. The valley pan, valve covers, carb and intake are just sitting in place for mock up purposes.
Not only is the flooring done, but I also built a 31 x 16 deck! Sheesh!
- Mike
1967 GTO
The Following User Says Thank You to Qball For This Useful Post:
Old 01-30-2021, 08:50 PM
Half-Inch Stud's Avatar
Half-Inch Stud Half-Inch Stud is online now
Engine paint job looks very nice.
I make that cast iron AC bracket satin Black.
The aluminum bracket i spray clear ( or machinery gray) to prevent corrosion.
Old 01-30-2021, 11:30 PM
Woo Hoo, floors and a deck, sounds like you have the Mrs. paid forward.... at least fora week or so... LOL
Sounds like a deluxe tire fryer, for sure. Maybe the power tour will swing your way again, soon!!!
Shut it off
Shut it off
Old 01-30-2021, 11:41 PM
Qball's Avatar
Thanks! The aluminum brackets are painted. They actually look pretty good!
- Mike
1967 GTO
Old 01-30-2021, 11:42 PM
Qball's Avatar
You wanna know what? I did such a good job on the deck, my reward is that I get to finish the basement! Go me! Ha ha ha!!!
- Mike
1967 GTO
Old 01-31-2021, 07:05 PM
Formulabruce's Avatar
Mike, the X plugs are for HEI applications. The 45 plug is Way too hot for running Any alcohol in the fuel. Highly recommend a #43 for summer only use. If you can't find a plug you like in the old school nomenclature, try looking them up with a "M" in front of the number. Example is "MR43TS" these are the marine version of same plug, will work fine. Will we get to hear it run on V8 radio ?
You can run a Delco 170 t stat as well.
The Following User Says Thank You to Formulabruce For This Useful Post:
Old 02-01-2021, 05:30 AM
Kenth's Avatar
Kenth Kenth is offline
.045" with a .5 Ohm coil and .035" with a 1.7-2.0 Ohm coil w/1.3 Ohm resistor lead.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 02-01-2021, 06:13 AM
jamaca85 jamaca85 is offline
i do 045 gap on my eddys with the hei. runs great
1970 firebird, 468, e heads,
Old 02-10-2021, 06:32 PM
Qball's Avatar
Ahhh, you've uncovered my double life! Yes, we will definitely be covering this on V8 Radio! I'm hoping I can get Kevin to make the trip up to bear witness to the first fire up and document it.
A little known fact, if you listen to the very end of the show, there's a start up and mild rev of an engine. That's my GTO before the build. After I'm back on the road, I plan to update that sound with the new engine sound.
Thanks for listening!
Edit: I found the R43TS's at my local O'Reilly Auto Parts. Picking them up tonight. Thanks again!
- Mike
1967 GTO
Old 02-11-2021, 10:24 PM
Get that sunny beach back on the road, for another burnout!
Not today, we’re getting way too much of your winter weather, here in Oklahoma, and it’s supposed to get worse in the coming week!
Shut it off
Shut it off
Old 02-11-2021, 10:28 PM
Qball's Avatar
Things are definitely moving forward! I legitimately should be back on the road this Spring/Summer.
Our winter weather cup runneth over. We had to share!
- Mike
1967 GTO
