Old 10-09-2020, 09:34 PM
footjoy's Avatar
footjoy footjoy is offline
Default American made u joint u bolts
does any one know where I can get some American made u bolts for 65 tempest?
I am talking about for the u joint.
greg
Old 10-09-2020, 10:46 PM
max 93 max 93 is offline
I bought some from Dennys Driveshaft several years ago. I don’t know where they are made though.
Old 10-09-2020, 11:35 PM
Scott Thelander's Avatar
I should have oem GM pair
scott68gto@comcast.net
Old 10-10-2020, 10:09 AM
tripower's Avatar
tripower tripower is offline
AMK has the US made fasteners, most are NOS. Scroll down to the bottom of the 12th page. Only issue is they require a $30 minimum order but only place to get the correct grade nut, bolts, etc.
https://www.amkproducts.com/wp-conte...BULK_25-38.pdf
Norm J
The Following User Says Thank You to tripower For This Useful Post:
Old 10-10-2020, 12:17 PM
HWYSTR455's Avatar
AMK is the only one that I can think of that makes them in the US. DANA Spicer is what the OEs used to use, at the time they were made in the US, are now a mix of US/China, but the China stuff will be moving back.
If you are just trying to support US-made stuff, it's a tough call, because even if they are made in the US, the steel can still come from China. (I am not sure where AMK's steel comes from). I'd like to think now that Pittsburg steel plants are roaring that it would be where AMK gets their steel, and it is fairly close by, with direct rail and air access.
The AMK facility is in Winchester, VA, and employs (mostly) local people, and are advocates for the local community. They are patriots at heart.
Aside from all that, if your concern is quality, the u-bolts are under very little load, and the DANA Spicer ones work fine. I may be mistaken, but think the nuts are specific, they are flat all the way across the faces, to bite more of the lock washers. My understanding is they are not grade 8.
Make sure your yoke is good. I've seen many damaged from years or incorrect u-joint installation where the locating 'nubs' for the caps are worn badly. No way you can properly center the joint in that case.
Old 10-10-2020, 12:34 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
AMK has LOTS of good bolts and stuff!
Skip Fix
Old 10-11-2020, 11:50 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Strange sells them, got some this year but didn't look like anything special
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
Old 10-12-2020, 08:03 PM
NeighborsComplaint's Avatar
https://www.ebay.com/itm/1964-72-GM-...cAAOSw0D5fKc2p
Triple Black 1971 GTO
