Old 04-20-2020, 05:06 PM
elefantrider's Avatar
elefantrider elefantrider is offline
Default Windshield Butyl Tape Size
What is the correct size width butyl tape for the windshield?
Old 04-20-2020, 05:19 PM
This is what I bought to do the front and rear windows on my ‘64 Tempest, I bought two boxes from PY while I was ordering other parts I needed.
Old 04-20-2020, 07:23 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
I used to use butyl tape years ago until I restored one of my GTOs and removed a butyl-ed in windshield. It was ridiculously easy to pop out, and I had used the proper primer. Since the reason for using laminated glass in the windshield is to help hold in the passengers in a frontal crash, the butyl tape's crappy adhesion defeats that feature.
I've since only used urethane adhesive from a caulking gun cartridge. MUCH better adhesion and better sealing too.
https://www.amazon.com/3M-08693-Uret.../dp/B000RW1XCK
The Following User Says Thank You to hgerhardt For This Useful Post:
Old 05-02-2020, 11:34 AM
Might use a combination of both Butyl tape and 3m Urethane. Butyl tape to set the height, and 3m to seal it better.
I'll try this on the rear window before I tackle the front.
