Old 04-02-2020, 08:28 PM
ladytata's Avatar
ladytata ladytata is offline
Default Heater hose and pvc
Replaced heater core today, and before I go cutting hoses, anybody have and good pictures of how the 2 hoses go(route)? Also would like a picture of the pvc and if it goes next to air cleaner or under. Thanks
Old 04-03-2020, 06:44 AM
ladytata's Avatar
Pcv I meant
Old 04-04-2020, 04:21 PM
sp4spd's Avatar
sp4spd sp4spd is offline
Here is a picture of how I routed my heater hoses. The assembly manual shows them routed this way.
The PCV hose just drops down to the valve from the manifold fitting.
Hope this helps��
Scott
74 Firebird Formula 400 4speed
70 Buick GS455 4 speed
Old 04-04-2020, 04:43 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
Heater hose routing for A/C car.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1993 Trans Am
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
2006 GTO
Old 04-04-2020, 06:52 PM
Is this for the SD TA?
SD's are different.
Old 04-04-2020, 09:19 PM
Held for Ransom's Avatar
If she had to ask, it's about the SD.
I believe it goes under the fuel line.
So long, farewell.
Old 04-04-2020, 10:33 PM
ladytata's Avatar
Yes,for sd. Very hard to find pics on 74, at least detailed close ups, and to actually know what is correct. Thanks for pics, would like to see some pcv pics of the tower clamp.....under shaker? Next to shaker? Pointed at 2 o’clock?
Old 04-04-2020, 10:52 PM
ladytata's Avatar
And my next question, doesn’t matter how many wire harness I pull out, the gray firewall loom seems to stop short. I know it gets taped along valve cover, but was there a second piece, taped? Since I stop short?
I changed the master also, just need to dig out a cover, today rebuilt alternator and it works....... yay! Tomorrow will be to get all the hoses figured out , and odds and ends back together from doing heater core....
Old 04-04-2020, 11:05 PM
SD PCV. How's this...
So long, farewell.
Old 04-04-2020, 11:06 PM
ladytata's Avatar
I like!
Old 04-04-2020, 11:08 PM
ladytata's Avatar
So I know I have to paint my master, but is that the correct “knot” tie around spark plug wires too?
Old 04-04-2020, 11:19 PM
Picture from a 1974 19,000 original survivor.
So long, farewell.
Old 04-04-2020, 11:22 PM
ladytata's Avatar
Good god, I just want to drive this b@@@@! Parting them is way easier.....
Old 04-05-2020, 09:15 AM
So, you're not going to add the inspection stamp when done?
So long, farewell.
Old 04-05-2020, 05:01 PM
OVERULD's Avatar
OVERULD OVERULD is offline
Teri, I’m glad you clarified the title of this thread. I was about to post: “Who the hell is this and what did you do with LadyTaTa? She knows better than to run heater hose in PVC!”
The Following User Says Thank You to OVERULD For This Useful Post:
Old 04-05-2020, 08:55 PM
ladytata's Avatar
Haha, Just slowing getting all the race stuff off, and fixing what doesn’t work, with trying to make it someone correct looking....not going all out on this car.. I bought it to drive, maybe even to take down the track once or twice.
Old 04-05-2020, 08:57 PM
ladytata's Avatar
😚😘 to many long days!,,,,
Old 04-06-2020, 09:51 AM
3tas4me's Avatar
Hope this helps��
Can you post up another picture or two of this same side of the engine? I have a wiring harness on mine that seems to clip on at the back top valve cover bolt and I have no idea what it is for.
1970 Trans Am
1971 Trans Am
1974 Trans Am
1984 Trans Am
1993 Trans Am
2006 GTO
Old 04-06-2020, 03:29 PM
sp4spd's Avatar
There are three wires coming to just behind the valve cover on my car(no a/c, HEI, 4 speed).
One is for the HVAC fan (black), one for the temperature sensor(blue) and the other is for the HEI battery power(pink).
I do have one other wire but that is power for the electric choke.
ID:	536527   Click image for larger version
Scott
Old 04-08-2020, 06:58 PM
ladytata's Avatar
Did sds have wire loom holders?
