Old 06-09-2019, 03:58 PM
mbeeman400's Avatar
mbeeman400 mbeeman400 is offline
Default Diff housing and axle tube paint color.
Want to detail the the diff housing and axle tubes in our 70 TA. From doing a search here, seems like black was the factory color on most Pontiac models. In some cases the axle assemble were fully painted to just partially painted !!
Thanks in advance!
Old 06-09-2019, 05:30 PM
Norwood's Avatar
Norwood Norwood is offline
Unpainted is correct
Old 06-09-2019, 08:35 PM
Formulabruce's Avatar
RPM is your friend on this one. ESC sells it.
Old 06-10-2019, 07:51 AM
notime's Avatar
notime notime is offline
72 Formula
Name:	Phone photos 1448.jpg
ID:	513857   Click image for larger version
Name:	Phone photos 1552.jpg
WWW.SUPERCARCREATIONS.COM
Old 06-10-2019, 07:55 AM
notime's Avatar
73 SD
ID:	513861   Click image for larger version
Old 06-25-2019, 11:04 PM
mbeeman400's Avatar
Originally Posted by notime View Post
72 Formula
73 SD
Thanks for everyone's comments and pics. Looks like cast iron gray for the middle section and silver/steel for the tubes, cover and backing plates.
Old 06-26-2019, 07:10 AM
Keith Seymore's Avatar
72 Formula
73 SD
Those are beautiful.
I'm a little surprised (...a little...) that they got nothing.
Trucks of the same area went through a small spray booth before body drop where chassis black was drizzled in the general direction of the top of the diff, axle tubes and brake drums. To describe it as "painting" would be a bit generous. They certainly look better just clean.
Olds passenger car photo from Lansing Assembly shown:
Name:	Lansing Chassis spray.JPG
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
Old 06-26-2019, 11:11 AM
dld's Avatar
dld dld is offline
Agree Keith.... if you guys grab a copy of Echoes of Norwood you find a few pics of cars on line being built up . There is a notation that the axle tubes are black the brake backing plates were unpainted as well as the center section.
A buddy of mine that has done several Norwood second gen Z28's told me he has seen paint on all the cars he has torn down for rebuild .in this area . This guy is very detailed on tear down posses.washing and documenting all areas of his project
as Keith said there may have been a black out area where black was added to non painted parts.?
this pic has been around awhile you may have seen . although its a 1st gen car it shows over spray on exhaust as if black was sprayed after some assembly
Old 06-26-2019, 12:44 PM
Norwood's Avatar
It’s called black out and yes the cars were haphazardly “blacked out” after assembly. I believe a search will pull up info
Old 06-26-2019, 06:23 PM
Judge273's Avatar
Judge273 Judge273 is offline
That pictures clearly show during assembly and tubes are black....
Mike/Illinois
Old 06-26-2019, 06:25 PM
Transamric's Avatar
I totally agree with the "black out" comments. I've had several very low mile unrestored 'A', 'X' and 'F' cars back in "the day" and they all had a very randomly sprayed black treatment on the rear axle and nearby areas. Back then a good friend of mine was a manager at a Chevrolet dealership. I'd asked him why this was done and why so sloppy. He believed it was done to improve the undercar appearance to new car shoppers who often would bend down to take a peek underneath. If left bare, they knew flash rust from humidity would already cause bare metal things to look old, or worse than they really were. It didn't have to be especially pretty, just good enough for a quick glance or two. I've always believed that to be a reasonable reason why this was done.
Old 06-26-2019, 07:55 PM
Norwood's Avatar
That picture clearly shows a 1st gen lol
Old 06-26-2019, 10:22 PM
mbeeman400's Avatar
So if you had to paint the axle tubes and backing plates. What would you do?
Car is a driver not a concourse car. Everything is black now. Just want to detail the rear. Thinking center piece cast gray, cover black...
Old 06-26-2019, 11:02 PM
Aus78Formula Aus78Formula is offline
Paint it dark steel grey and cast iron and call it done. I had mine powdercoated, the steel colour came out like a bright silver fresh steel and was disappointing, but it isn't seen.
Old 06-27-2019, 06:43 AM
I would do it just like in notime's pics, or just paint everything underneath all black. Whatever you want (it's your car).
But I would not in any fashion duplicate the haphazard application of chassis black.
K
'63 Grand Prix
Old 06-27-2019, 02:41 PM
dld's Avatar
dld dld is offline
I stated in my post it was a 1st gen car lol
see pic... this is of a 2nd gen f body at Norwood note the tubes .
it is noted in book that the case and backing plates were not painted . But as said there may have been a black out later in assembly
Old 06-28-2019, 12:50 PM
Norwood's Avatar
Directed at Mr Sparks
Old 06-29-2019, 06:00 AM
Judge273's Avatar
Did you read the book?
Mike/Illinois
Old 07-01-2019, 11:25 AM
dld's Avatar
dld dld is offline
Me, yes. like it . lots of incite into G.m. the union and of course f body cars.
good pictures of plant and car build out.
https://www.norwoodassemblyplant.com/home-page.html
Old 07-02-2019, 07:21 AM
Judge273's Avatar
Directed at Mr. Norwood.
Mike/Illinois
