Old 06-03-2019, 11:10 PM
justincampbell's Avatar
justincampbell justincampbell is offline
Default This things connected to that thing? Seriously though...
So I have a couple things under the hood of my '73 Formula that appear to have been disconnected for years. I assume they should have vacuum hoses on them? Since there are 3 ports on each, are they supposed to be connected to each other? I know there is a temp activated switch/sensor similar to this up front in the coolant crossover, but honestly I know nothing about these two. The fact that they are unhooked has no bearing on the how well the car runs(it runs strong). However, after I clean things up, I'd like to have everything "how it was". So, how was it?
ID:	513502   Click image for larger version
"What the hell's wrong with freedom man? That's what it's all about." (Billy)
"Oh yeah, that's what it's all about alright... but talkin about it and bein it, that's two different things." (George)
Easyrider
Old 06-04-2019, 02:22 AM
Scott Thelander's Avatar
nice , rare., distributor .....................
Old 06-04-2019, 06:57 AM
necdb3's Avatar
necdb3 necdb3 is offline
It's an emission control device to go between the distributor and manifold for vac advance. If hooked up, will remove vac advance from you distributor unless in high gear. Look up "TCS system" in the search bar.
Old 06-04-2019, 09:57 AM
Thanks! Now at least I have some idea what the heck I am looking at.
Easyrider
Old 06-04-2019, 08:01 PM
SD73's Avatar
SD73 SD73 is offline
I've got some articles and factory diagrams I've collect that if you like I can forward to you. Just PM me your email address if you're interested and I'll forward them along.
Old 06-04-2019, 08:52 PM
That would be great! Thanks!
Easyrider
