Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
Closed Thread |
900HP Pontiac 535 all Aluminum engine for sale - $15,000
Engine built by Kauffman Racing has 50 passes since freshened and 68 passes since new. Over $25K invested. Selling for $15K.
Kauffman MR1 Aluminum Block Bore - 4.350” Stroke - 4.50” Crankshaft – Ohio Forged Steel Journal size - 3” main Connecting Rods - GRP 6.8” Aluminum Pistons - Ross with Total Seal Gapless 2nd ring Camshaft - Comp Standard Journal Cam Specs - (51000-13) 790 int. – 773 Ex. – 112LB Duration 277* - 282* grind # P812305B/2237B R112 Heads - high port Kauffman with offset valve train. Flow numbers - 400cfm. Chamber CC - 64cc Compression ratio - 14.7:1 Victor Pontiac Intake manifold w/plenum work and ports matched. Intake Spacers welded. Valves - Int. .220 Ex. .170 Springs - Comp Pacaloy Lifters - Isky Red. Pushrods – Hardened 3/8” Rockers - T&D shaft 1.7 Custom made Tall Aluminum Valve covers with recessed Allen head bolts Water pump – Menzier Electric Aluminum (Red) Distributor – MSD Pro Billet Vacuum pump – Moroso 3 vane Harmonic balancer – Rollmac Oil pan – Custom Langer split rail – 7qt Oil pump – Melling 60lb Crank scraper – built into oil pan Valley pan – Aluminum Email: rasoule@charter.net Last edited by Robsinno1; 04-18-2019 at 01:23 PM. |
What did it run in the car and weight of car?
this is the car it was in. i believe it was right at 2500 with driver. we bought the car and with an iron ia2 and gutsram it weighs 2600 with driver
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1 |
I was running 8.20's in Norwalk in 2017 with that motor.
A second class drive is better than a first class walk. |
It ran 8.26 at 162 mph in a 74 TA that weighed 2320 lbs. Bought the motor from Pearl Blue Bird, but never used it. Too many modifications required to make it work in my car.
Sorry, it was not in that car....not the same car or motor
Yes same car same motor Good Luck with the sale .. Free Bump...
Sorry but you are wrong, this is not an iron IAII block, it is a Kauffman MR1 Aluminum block as stated. Here are pictures of the car it was in with the motor in it and next to it.
this is the link i put in my response. i don't know why it didn't show up. i bought deryks car. i put an iron ia2 in it. sorry
Nice build and a great price GLWS .
I never said it was a iron block you got from a good friend of mine .. Good Luck
Sorry that was meant for Zeek, and thanks.
PM Sent.
Spent some time talking with Bob about this engine. This is a really good price for a proven combination.
bump
Are you looking for a less radical engine? If so, I have the engine below if you are interested in some type of trade? Dyno time only on it.
http://forums.maxperformanceinc.com/...d.php?t=776790 |
BUMP
Kauffman MR1 Aluminum Block Bore - 4.350” Stroke - 4.50” Crankshaft – Ohio Forged Steel Journal size - 3” main Connecting Rods - GRP 6.8” Aluminum Pistons - Ross with Total Seal Gapless 2nd ring Camshaft - Comp Standard Journal Cam Specs - (51000-13) 790 int. – 773 Ex. – 112LB Duration 277* - 282* grind # P812305B/2237B R112 Heads - high port Kauffman with offset valve train. Flow numbers - 400cfm. Chamber CC - 64cc Compression ratio - 14.7:1 Victor Pontiac Intake manifold w/plenum work and ports matched. Intake Spacers welded. Valves - Int. .220 Ex. .170 Springs - Comp Pacaloy Lifters - Isky Red. Pushrods – Hardened 3/8” Rockers - T&D shaft 1.7 Custom made Tall Aluminum Valve covers with recessed Allen head bolts Water pump – Menzier Electric Aluminum (Red) Distributor – MSD Pro Billet Vacuum pump – Moroso 3 vane Harmonic balancer – Rollmac Oil pan – Custom Langer split rail – 7qt Oil pump – Melling 60lb Crank scraper – built into oil pan Valley pan – Aluminum |
This is a steal, most likely way more than $25k invested too
Dave Polichena |
Engine built by Kauffman Racing has 50 passes since freshened and 68 passes since new. Over $25K invested. Selling for $15K. Kauffman MR1 Aluminum Block Bore - 4.350” Stroke - 4.50” Crankshaft – Ohio Forged Steel Journal size - 3” main Connecting Rods - GRP 6.8” Aluminum Pistons - Ross with Total Seal Gapless 2nd ring Camshaft - Comp Standard Journal Cam Specs - (51000-13) 790 int. – 773 Ex. – 112LB Duration 277* - 282* grind # P812305B/2237B R112 Heads - high port Kauffman with offset valve train. Flow numbers - 400cfm. Chamber CC - 64cc Compression ratio - 14.7:1 Victor Pontiac Intake manifold w/plenum work and ports matched. Intake Spacers welded. Valves - Int. .220 Ex. .170 Springs - Comp Pacaloy Lifters - Isky Red. Pushrods – Hardened 3/8” Rockers - T&D shaft 1.7 Custom made Tall Aluminum Valve covers with recessed Allen head bolts Water pump – Menzier Electric Aluminum (Red) Distributor – MSD Pro Billet Vacuum pump – Moroso 3 vane Harmonic balancer – Rollmac Oil pan – Custom Langer split rail – 7qt Oil pump – Melling 60lb Crank scraper – built into oil pan Valley pan – Aluminum |
Closed Thread |
