EFI Tech All things EFI and making classics modern!
Old 02-06-2019, 01:20 PM
highrisk's Avatar
highrisk highrisk is offline
Default Timing Map for 428 EFI
I have been kicking around the idea of adding EFI to my 65 GTO with a 69 428. In preparation I have been doing a lot of reading which includes the installation manual to see if I have the basic knowledge (or lack thereof) to be able to do this and have an end result better than what I currently have. One thing I noticed in the instructions, if the EFI ECU is going to control the timing, they want you to enter a timing map for your engine for the cranking, idle, cruise, and WOT timing. So, I am going to ask the experts on here what I should use for these values. Here are the specs for my engine and the current timing. The unit I am looking at is the Holley Sniper 4150, 550-511.
The ignition is a Mallory 6AL with a Mallory Pro Master Coil, and Mallory Unilite Distributor. If I do this the distributor will be replaced with a magnetic pickup unit so the EFI can control the timing. I am using ported vacuum advance but that will be disconnected with the EFI. This is the current timing curve; idle 12, 1000 15, 1500 22, 2000 32, 2500 36. The mechanical timing is 24 degrees. Recently I had the engine and carburetor tuned a little better and he increased the idle timing to 15 degrees which gives me a total of 39 degrees.
The engine is a 1969 428 out of a Grand Prix and has been bored 40 over which makes it a 435. It has its stock crankshaft and the connecting rods are out of a 421SD. The pistons are RaceTech 5cc flat top pistons and the pushrods are made by Butler Performance. The rockers are 1.65 roller rockers by Harland Sharp. The timing chain is the double roller chain from Butler Performance. The heads are Edelbrock 87cc round port heads that were originally built, ported and polished by Bruce Fulpner of Rock and Roll Engineering and they were reported, in the June 1996 issue of High-Performance Pontiac magazine, to flow 300cfm at .550 lift on the intake. The intake is an Edelbrock RPM that has been ported and polished to match the heads. The block was decked to .001 and the heads were also shaved to give a final compression ratio of 9.85 to 1. The cam shaft is a Lunati VooDoo 60903 (10510703) with an advertised duration of 268/276 and 227/233 at .50 lift and a gross valve lift of 538/554 with the 1.65 rockers. The carburetor is a 1976 800cfm Quadrajet that has been tuned to the engine. I have not had the engine dyno tested yet but DeskTop Dyno estimates it at 476HP and 573ft/lbs. torque with a high flow intake and 509HP and 574ft/lbs. torque with a max flow intake. I will be very happy if this engine falls anywhere within these numbers.
The transmission is a 5-speed Tremec TKO600 Street and Strip Transmission with the .64 overdrive. I have the McLeod RST Twin Clutch set up for street use. I was able to use my stock 11” flywheel with this setup. The rear end has 3.36 gears and posi-traction and with the 5-speed at 70MPH in fifth gear the engine only turns 1890RPM.
So, what would be good timing numbers to enter in the setup for cranking, idle, cruise and WOT? This is what Holley recommends; cranking is preset to 15, Idle Timing – 18-34, Cruise Timing – 32-48 is typically used when cruising for optimal fuel economy, Wide Open Throttle Timing (WOT) – Older V8 engines are usually between 32-38 degrees.
Thanks for the advice,
Dale
Tremec 5 Speed
U.S. Army Retired
Retired Helicopter Pilot
Old 02-06-2019, 01:27 PM
JLMounce JLMounce is offline
This area tends to get over-thought, especially with these TBI units. What you're providing as the timing map, is essentially the mechanical + advance curve of your standard distributor. If you know your curve currently and your engine likes it, just interpret that data and move it over to the EFI unit.
The only main difference is you have the ability to set a cranking timing setting unlike a mechanical curve where that's basically static depending on where the initial timing is set. Typically you'll set this a little lower to aid in turning the engine over easier.
From there, just take your current figures for your initial advance which is your idle timing, total advance which is your WOT timing and the amount of advance you have in your vacuum can which is your cruise timing. The unit's software will interpolate that data and add or remove timing as needed based on rpm and MAP reading.
-Jason
1969 Pontiac Firebird
Old 02-06-2019, 01:29 PM
steve25 steve25 is offline
So you had one of Fulpers porting jobs that in really where just a polish job done to them , he soaked a lot of guys with that ploy, so don't feel bad!
highrisk's Avatar
Thanks, sounds simple enough.
Dale
Tremec 5 Speed
U.S. Army Retired
Old 02-06-2019, 01:35 PM
No worries.
You can of course also run these things without timing control. Because the timing map is pretty basic, unless you need the ability to retard timing for nitrous or boost, there's not a ton to be gained over a well curved mechanical distributor.
That said, the Unilite's are pretty noisy and the EFI units don't like them all that much. I certainly had issues with mine on my FiTech. Given that, if you're going to go the sniper route, I'd get a new distributor and at that point you might as well utilize the timing control.
-Jason
Old 02-06-2019, 01:36 PM
highrisk's Avatar
I did not have the work done on the heads. This engine was in the car when I bought it and I was able to track down the history of the engine because a copy of the magazine article was included with the car and the heads were stamped with his information on them. The engine was originally built for a Firebird and ended up years later in this car. Then I tore it apart and rebuilt it when I bought it and had a lot of extra work done to it.
Dale
Tremec 5 Speed
U.S. Army Retired
Old 02-06-2019, 01:43 PM
68lemans462's Avatar
68lemans462 68lemans462 is offline
What is wrong with your Q-jet that is pushing you toward the EFI, or do you just like eye candy?? A properly tuned Q-jet will run just as good as any EFI at a far lower cost/level of complexity in my humble opinion. You wont really get much/any ROI with an EFI system relative to a Q-jet.
1968 Lemans. 37,000 original miles. GTO clone. 462ci/KRE 290 heads. UltraDyne 280/288 Solid/850 Qjet by Cliff/Performer RPM/TSP 9.5" in TH400/8.5" 3.42 gears/3950# Race weight/12.58@106 at Bandimere speedway high altitude
Old 02-06-2019, 01:45 PM
highrisk's Avatar
No worries.
The Unilite was on the engine when I got it so I just kept it. I thought this would be a good time to get a new distributor so I might as well get something that matches the Sniper. It would be nice if Holley made a Sniper Hyperspark distributor for the Pontiac engines then it would be a simple plug-n-play and you wouldn't have to lock out the advance and remove the vacuum. I didn't realize the Unilite had a lot of noise with them. That is another reason to switch it out because Holley warns about electrical interference with this unit.
Dale
Tremec 5 Speed
U.S. Army Retired
Old 02-06-2019, 01:52 PM
With the Sniper, the best unit to use on a Pontiac is the FAST dual sync. It does the same thing and should hook right up to the Sniper harness.
-Jason
Old 02-06-2019, 01:53 PM
highrisk's Avatar
Nothing really, I have had some tuning issues with the Q-Jet but overall it runs fairly well. I always get the feeling this engine has more capability that the current carburetor isn't bringing out. I am also planning on doing some cross country trips (Route 66 and Power Tour) and I thought the EFI would make life easier as the car is driven at different altitudes and temperatures. Part of my intention with this build was to have a more modern driving experience while keeping it stock looking and I thought the EFI would be a nice addition.
Dale
Tremec 5 Speed
U.S. Army Retired
Old 02-06-2019, 02:30 PM
6x400gmc 6x400gmc is offline
Send a message via MSN to 6x400gmc
Dale
This is exactly why I converted (Edelbrock's port fuel system with distributor). I'm not the greatest carburetor tuner, and I felt I was leaving HP on the table with the Performer intake. The lower TB allowed the Victor intake to fit beneath my hood.
Later this month I'll have my car at a chassis dyno to dial everything in, though it's running great now. The instant starts are what really impress me. Whether 50 in the garage, or having run for an hour and really heat soaked. I know you can accomplish that with a carb, but I never could.
Britt Bettell
1975 Firebird / 1970 4" stroke 400, 6.800" Rods, 87cc Edelbrocks, XR-288-HR roller cam, Harland Sharp 1.5 roller rockers, Edelbrocks Pro-Flo4 port fuel EFI, Super T-10, 3.73 Posi.
Old 02-06-2019, 02:52 PM
highrisk's Avatar
Britt Bettell
Did you notice any increases when you switched to EFI? Most reviews I have read people were impressed with the throttle response and it felt like the car had more power, even though there might have been no actual increase in HP. And, almost everyone talks about the easy starts and no more rich idles. My wife hates when I have the car idling in the garage because it makes the garage stink for hours.
Dale
Tremec 5 Speed
U.S. Army Retired
Old 02-06-2019, 04:00 PM
Your above question largely depends on the current state of tune of your carb and ignition system.
One of these TBI EFI systems isn't going to create more power than a properly dialed in carburetor. The people that claim power increases typically eith had a carb out of tune, incorrect size/type for their application etc.
What the EFI excels at over the carb is in driveability and adaptability to different driving conditions. Fitted with a proper modern fuel system, cold and hot start issues as well as vapor lock are decreased if not all together eliminated. Throttle response is improved and fuel delivery during rapid and sustained acceleration is improved.
68lemans462 isn't wrong in his statement, but that statement only applies when you have a properly dialed in carb. The further from dialed in your carb is currently, the more benefit you'll see in the switch.
In my personal experience, I went to a FiTech because I was having a terrible time with vapor lock. I had done fuel line heat shielding, wood and phenolic spacers, carb heat shields, new fuel pumps. During the summer I was only able to drive the car for about 20 minutes before it became a reliability issue on my car. I had spent quite a bit of time working on my carb setup and it was probably about as good as I could get it for an e-carb. When I installed the FiTech, I didn't really see a power increase, but not a single time have I dealt with vapor lock since. I went from putting maybe a couple hundred miles on the car a year, to now having put about 8000 on it in the past 2 years.
When we purchased my wife's 71 Chevelle, one of the first things we did to it was a FiTech. The difference on that car going from a double pumper holley (out of tune and the improper carb for a heavy automatic car with a mild 350) was dramatic.
I'm not in the EFI is always better camp. I'm in the use, what is best for you and how your drive the car camp. For me, that cheapo chinese EFI system was the best money I've ever spent on my car.
-Jason
Old 02-06-2019, 04:24 PM
highrisk's Avatar
Yup, I agree with everything you said and echo the reasons for the EFI switch. I have had the car in multiple times to get the carburetor properly tuned, but it never seems right, I am not a carburetor guy so my knowledge of tuning a carburetor is limited. It doesn't run bad, but it doesn't run great. I am thinking it will be more responsive and the drivability will go up. No more hard starts, better throttle response, better drivability, and more adaptive to changing driving conditions on cross country trips.
Dale
Tremec 5 Speed
U.S. Army Retired
Old 02-06-2019, 05:53 PM
Formulajones's Avatar
Dale
You'll find that part especially nice if you do the Rt 66 cruise. We do that cruise at least 2 times a year. Since you're coming from back East you'll experience quite a bit of elevation rise from where you currently are. Most guys that do the cruise from back East don't have horrible issues with it, but some do. You'll be over 7,000 ft in the Flagstaff area (DA's higher in the summer time), and elevation is up and down from there, and back near sea level when you reach the California portion of the drive.
That's what makes the EFI sweet. It makes calibrations on the fly. I deal with it (with carbs) daily, and it's a fair amount of time spent in tuning to get the carbs happy to deal with the various conditions out here.
Old 02-06-2019, 06:01 PM
highrisk's Avatar
Yeah, I was stationed at Ft. Carson, CO (Colorado Springs) in the mid 80s and had a 66 GTO with a Holley carburetor and it was a challenge just going from our home in Fountain up to Breckenridge. A lot of problems on hot summer days with vapor lock. I did everything I could to make it run better. Would have been nice to have had these aftermarket EFI systems back in the 80s.
Dale
Tremec 5 Speed
U.S. Army Retired
Old 02-06-2019, 08:31 PM
Dale
I wouldn't say I saw any increases, (not by seat of the pants anyway), I just noticed how much smoother everything was. Idle to Cruise, Cruise to WOT, Recovery from WOT (drops right back to a stable idle, immediately).
The throttle response throughout is more defined with no lags or bogs. Of course, the starts are nice. The first very first fire-up was immediate (even though I had No. 5 and 7 wires crossed at the cap.) with the intake air temperature reading 58 degrees. After I shut down and fixed that boneheaded mistake, the car fired right back up and I got the idle and timing set correctly.
The third start was here: https://youtu.be/L1kNCXROdpU
Setup was easy, I answered a few questions and it loaded a base map for the computer to then modify as it learned. The first drive was a little rough, but after about 5 minutes the ECM figured out what was going on and adjusted what it needed to.
I drove yesterday for about 30 minutes (80 degrees outside) until the car was good and hot. Stopped for a burger for about 15 minutes, then fired the car right back up. It starts like my 2015 Chevy truck.
I didn't do it for power, or mileage.
Britt Bettell
Old 02-06-2019, 09:09 PM
Firebob's Avatar
Firebob Firebob is offline
The biggest change to the power seems to me is from the fact that the qjet had that lag time when the secondaries opened and the power came on more gradual. The Holley fuel delivery is pretty immediate. Just a different feel altogether. I don't really think it has any more power.
Robert
69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always )
http://youtu.be/eaWBd3M9MN4
Old 02-06-2019, 09:30 PM
highrisk's Avatar
Britt Bettell
Thanks for sharing the information and the video. I really didn't think it would actually have more power, just seem like it because it is more responsive. Your car sounds really good.
Dale
Tremec 5 Speed
U.S. Army Retired
Old 02-06-2019, 09:33 PM
highrisk's Avatar
Thanks for the information. This kind of first had knowledge I am getting is what I need to make my decision on whether or not I will spend the money to do this and whether it will make a big enough difference. Everyone I have talked to are glad they made the change to EFI.
Dale
Tremec 5 Speed
U.S. Army Retired
