TIMING BELT COVER SCREWS
I thought there was a post with info on suitable replacement SCREWs for the (3) mounting screw used on the Timing Belt Cover but can't seem to locate it.
Anyone have this info; ? IIRC they were sourced from a Motorcycle parts sight. Thx.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
FOUND IT/THEM...
The OE screws for the 66-68 Belt Cover always seem to be missing.
These are a great alternative part to use. If anyone has 3 OE to sell LMK. Cheers.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 10-23-2023 at 06:40 AM. |
Looks like a pretty good substitute. I.ve looked for new ones for a long time and never found anything closer than that. I assume the longer threads have no effect? Thanks for the info, Jeff.
Not much activity when it's so cold,
I did however finally get a set of these myself and must say these are almost spot on. I searched out a set a little less costly with a slightly less shiny finish. These are 5/16 - 24 X 9/16 Truss Head Screws.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 10-23-2023 at 06:44 AM. |
Timing belt cover screws
I seem to remember there was a post about this. Someone found them on Ebay. ???
If you search around you can find better deals.
