64 GTO Heater Control, Weatherstrip & Various Other
A-Body parts. Descriptions accurate as possible with any issues noted. Part number fitment based on info I have; verify correctness for your application. Shipped from Chicago, IL area, 60516. PayPal preferred. PM if interested. All prices plus shipping; flat rate when possible.
64 GTO/Lemans Heater Control- Good chrome and indicator. Switch tested OK for continuity. Minor rust on lever bracket but levers move freely. All mounting studs & cable pivots intact. Refinished in a close to original color. Includes brackets & cables. NOTE: This is a daily driver/mild resto part, or a good foundation for a complete resto. $100 64 GTO/Lemans Dome Lens- NOS #4817415, opened for inspection. This is the standard rectangular lens. $12 Fuel Tank Sender- NOS GM/AC Delco 90 ohm sender for 65-67 GTO; may fit other GM A-bodies of the same years. Single 5/16” line. The ground wire ring terminal is not original. Purchase from Year One years back. The box part number is for a 64 30 ohm sender (what I needed) but my guess is that in later years GM supplied the 90 ohm for all applications. $125 Trunk Weather Strip- NOS #9825829 OEM latex skin, approximately 24 ft. Box (a lot of shelf wear) is dated 10-82. Weather strip is clean, soft, pliable, no tears or cracks. Bonding joints at 9ft. and 18ft. Per the 4/75 parts book - # 9825829- 1964-75 Pontiac all except Ventura hatchback $300 Parking Brake Cable-Front-NOS #1394278- Goes through the frame and connects to the park brake pedal. Original packaging though deteriorated. 45” length. Per the 4/75 parts book fits the following: 1964-67 Tempest, Lemans and GTO, except Hydramatic transmission (TH 400) 1968-69 T/6-T/8 with 3-speed column-shifted manual transmission—Second type 1968 1968-69 T/6-T/8 with 2-speed or M38 3-speed automatic transmission—Second type 1968 1970-72 All A-bodies with 350 engine and 3-speed column-shifted manual transmission 1970-72 All A-bodies with 350 engine and 2-speed or M38 3-speed automatic transmissions $65 Parking Brake Cable-Pair-Rear-NOS, don’t have PN -Fits 64-67 A-bodies, may also fit later years. 35” length. For reference matches up my original 64 cables. Note: one cable has a red bushing and one has black. Same cables probably different cable/bushing vendors. $65 GM NOS heater fan cage #3905776. This is a metal cage that measures 5 & 1/2” across top, 2&3/4” high, and uses a set screw mounting. Listed to fit 67-70 All except A.C. May fit other GM makes/models so best to compare your cage to the specs listed to be sure this is the one needed. $70 |
Few more part pics.
more parts
last one
64' parts
PM sent... heater control and dome light...
Sale pending on heater control and dome lens.
Sold-Heater control and dome lens.
Other items still available.... |
TTT
Trunk weather strip reduced to $280 plus shipping |
Bump
TTT
