Old 07-13-2017, 06:28 AM
oldgoat455's Avatar
oldgoat455 oldgoat455 is offline
Default Help with 69 front light harness
I am hoping someone can help me with the routing for my new front wire harness. I have a 1969 GTO with hideaways that were added many years after the car was built. The 69 shop manual has a generic wire routing diagram that is intended for every Pontiac produced, and it isn't very helpful. I know the harness travels along the top of the radiator core support, but that is about it. My question, do I need to remove the front bumper and valance to properly route the harness, or should I be able to do it with them in place? It looks like I will need to judging from how the original wire harness is routed. However, since my car has been worked on previously, I don't know if this factory correct or has been changed. Currently I can't remove the harness without either cutting it or removing the front bumper as it is routed between the core support and a bumper bracket. Any help would be greatly appreciated. Thanks!
Old 07-14-2017, 08:30 AM
charles bledsoe's Avatar
charles bledsoe charles bledsoe is offline
Hi oldgoat455-
I removed my front clip to redo my engine bay last fall. If I remember correctly I did have to remove both the front bumper and the valance to get the light wiring harness off. Both come off easily. I would go that route before cutting the existing harness. I'm sure others will chime in. Welcome to the forum!
1966 GTO Vert automatic.
1969 CR Judge Ram Air III 4sp Pattern Car.
1969 GTO standard 350HP TH-400.
2006 GTO Phantom Black 6spd.
1972 Formula 455HO Ram Air.
1976 LE Trans Am 50th Anniversary Edition with T top.
1976 Formula 350.
1977 Grand Prix Model J 350.
1978 Trans am 400 Pontiac.
1979 Trans am 403 Olds.
1968 Olds 442.
1971 TR6.
Old 07-14-2017, 09:28 AM
oldgoat455's Avatar
That's what I was thinking. I have had both valence and bumper off the car in the past, not hard, just didn't want to do anything that was unnecessary. Thanks for the welcome and your help. I've been a member for some years now, just have not posted as I can usually find answers in previous posts.
Old 07-14-2017, 11:07 AM
Scott Thelander's Avatar
Default Hello
I am with
Charles
If you want to hook it up correctly the ground wires are screwed in to the front upper corners of the core support ... and almost impossible to get to with bumper on..
