66 auto kick down switch
Has anyone here ever converted the 66 under hood kick down switch to the switch that works off the gas pedal,, (67 - 68) set up? If so any info would be great. Thanks, Hank
I'm wondering about this exact same mod. Any experience here would be great to hear about. Thanks.
66 kick down switch
I have a complete set-up from a 67 that look like it might bolt right in but not sure. Haven't got to doing that yet to see. I put a tri-power on this Bonneville with the progressive linkage. I have the kick down bracket and switch for the vacuum linkage but will not work with the progressive linkage, Interference problems.. I'm sure someone else has had this problem before.
I used a 2bbl bracket and regular switch on mine like that. Worked fine.
I have seen the under pedal done. Should work fine.
"If you do everything you'll win" -LBJ 13 Smiles per Gallon: 66 Bonneville wagon 66 Bonneville 2d HT - In perpetual progress |
