OHC-6 TECH Over Head Cam projects, questions and advice.
Old 01-01-2017, 05:48 PM
Jeff Hamlin's Avatar
Question M&H; SPRING RING BATTERY CABLES
Anyone here have using them?
Looking for insight on fit & finish.
Thx
Old 01-01-2017, 06:24 PM
GTOWAGON's Avatar
GTOWAGON GTOWAGON is offline
I currently have a 69 judge at the house for some work and it has them on it they look and work right
When you really do something right it's like you didn't do anything at all
1931 Pontiac 5 window coupe OHC6 powered
2015 GMC Yukon SLT
Old 01-01-2017, 08:20 PM
Chris,
Sorry I should have been more clear, I was looking at their OHC 6 cables listings and wondering about length.
I know the cables are decent, but are the wrong diameter and only avail in black
just didn't want to commit and find out there also to short as well.
I'll have to give them a call to see what the lengths are.
Old 01-03-2017, 11:50 AM
marxjunk marxjunk is offline
Jeff, i have some NOS Packard for sprints i believe..i recently rediscovered them..they are all in Packard boxes..and i have them ID'd
in the 60s and 70s, when ya went to a service station, these are what they had in stock..they all came from the estate of a Skelly station owner...they are all black, no red cables, but they are listed as POS and NEG
I will look thru them here in a day or two, ive sold quite a few here in the past, i just packed them up when i moved and lost track of what i have
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 01-03-2017, 06:37 PM
Thumbs up
Mark,
Sounds good.
Looking for 24 & 39"
I have some oem #s if that would help.
Old 01-04-2017, 06:54 AM
FWIW;
M&H indicated their cables are 31 & 41"
So these are close to OE lengths for anyone looking.
Old 01-31-2017, 11:00 PM
PMD1969's Avatar
PMD1969 PMD1969 is offline
Thumbs up
I too would love to see pictures of these cables.
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213)
99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale
http://sohcsix.yuku.com/forums/1/OHC-lounge
Wanted: 1969 OHC "H" Camshaft
Old 01-31-2017, 11:19 PM
i found them last week...i just havent had time to deal with it all..ive been on the road for work. i will sort thru them etc and see what i have..
Mark..
The Goat whisperer
Old 02-01-2017, 08:04 AM
I recently picked up what I would almost refer to as Service Part/cable.
They are DP spring rings but have no part number stamping on the cable, more of a reference number to size.
This is the 41" I am currently using in place of my NOS OE which have started to show issue.
This a a much heavier/larger Dia cable compared to the OE and has a 1L-41 stamped on it.
Perfect length and I like the idea of it being larger. Most will never know it's not correct.
Old 02-01-2017, 01:09 PM
PMD1969's Avatar
Have you tired the Spring Ring repops? The only thing I noticed on them is that they are missing the "GM" marking on the top of the end clamp to the battery. I keep seeing two things on these cables. One is the color is black for both the pos/neg of the cables. Seems to be true for ALL GM cars back during that time. I have no idea how they marked them for neg/pos but the colors were all black. Found most of this info from various GTO forums.
The other is the length. I have a Firebird so the length of the negative cable is super short. What I have now is a good 12" too long and is looped to keep it from getting into the fan while driving. The pos was a bit long but worked. These are NOT spring ring cables but just the 2A cables you can buy at any parts place.
Old 02-02-2017, 06:58 AM
I have not purchased the M&H cables.
I didn't want to drop $100+ on cables at this time.
I went hunting and came across the NOS. I was able to find a few for $30 and under.
Since it was a crap shoot I just took a guess that the longer cables would be + and so far this has proven to be correct.
If these last as long as the NOS have, then I will not need to address this issue for another 10+ years
Now I'm working on a hidden battery shut off so I don't have to keep disconnecting while parked in the garage or showing with the hood open all day, it is the constant on and off with the old spring cables that caused most of my past issues.
