Rear Axle Shaft
The '69 Bird needs a new rear axle shaft. I've researched the major catalog parts suppliers (Jegs, Summit Racing, Ames), as well as the auto chain stores (Autozone, etc). It seems like there are only two manufacturers: Yukon Gear & Axle and USA Standard Gear. Any recommendations for either?
A good good USED straight, never chewed Pontiac 8.2 axle would be my choice before ordering any cheap import axle.
On '69 Birds, there were 4 different axles used in the Pontiac 8.2 rears. The dimensions of the bearing "ends" of the axles are different between sealed & tapered bearing axles. The axles are: -Std axle with sealed axle bearing -HD (hot forged) axle with sealed bearing -Std axle with A9 tapered bearing & external seal (National 712146). -HD (hot forged) axle with A9 tapered bearing & external seal. The latter 2 axles, next to never go bad, one either has to curb one, or break it... so assume you have one of the sealed bearing style, that the archaic design axle bearing has chewed the bearing mating surface up. The std duty version axle are not obscenely hard to find, used, they also were used in nearly a million Pontiac A body's & '69 GrandPrix's, not just '67-69 Birds. The HD version were only used in HD Safe-T-Track rears & IF your Bird has a factory 3.90 HD STT rear in it with sealed axle bearings, it's best to give Moser Engineering a call.
Thanks for the great info ....never new there were 4 different axles used on the 8.2.
And you guessed right, my axle has the sealed bearing with some kind of retainer collar right next to it. The sealed bearing was bad, no longer press fit against the axle shaft. I grinded a slot almost all the way thru the retainer collar and was then able to worked it off with a slight bit of prying and tapping. The sealed bearing was so loose that it slid right off. Maybe I'm still learning the terminology, but the axle surface is not chewed up. In fact, it's very, very smooth. But the diameter of the shaft is worn down where the bearing used to be. It's a smaller diameter than the shaft diameter under the retainer collar. Per your advice, I'll search around for a good used axle shaft. Thanks again. |
How do you identify the HD axle versus the regular one. I know they were used in conjunction with the nodular rear STT package but is there a way to ID the axle shaft itself visually?
My Break Away Squad 1969 Fbird (base OHC, 350, 400HO & Sprint Cvt’s - 400HO & TA ht’s) 1969 Custom S 2dr ht 1969 LeMans (2dr & 4dr ht & Cvt) 1969 LeMans Safari wagon 1969 GTO (2 Cvt, 2 ht & Judge ht) 1969 Cat (3 Cvt’s & 2dr ht) 1969 Ventura wagon 2 seat 1969 Exec 4dr post 1969 Bonnie Cvt & 2 wagons 1969 Bonnie Brougham (4dr ht & Cvt) 1969 Grand Prix 2 SJ’s 1969 2+2 2dr ht (Canadian) |
John, sure, the Pontiac 8.2 HD forged axles are tapered & have a rough texture the full length. As an original Pontiac 8.2 axle, there will only be one access hole in the axle flange. The standard duty Pontiac 8.2 axles are a consistent thickness & are fully machined, you will see the lines.
good to know, I never paid attention, I have a few spares from a 69 Fbird 3.55 posi axle housing, I'll have a peek at them.
Dutchman
After complete rear end rebuilds in both cars, I didn't want to take any chances of a stock axle letting go and causing a bunch of damage. Great product, great service. I wouldn't say cheap, however. But I like the peace of mind. Check them out at http://www.dutchmanaxles.com/bop-sto...-pob-pair.html Last edited by propuckstopper; 10-07-2016 at 04:33 PM. |
I put Yukons in my 67 got them from summit.
