I want to rebuild my studying column because I have it out of the car. I do not have it apart, but I know there are 6000 little pieces in them. I've looked around and never been able to find a rebuild kit for these 2nd gen steering columns, but I thought I'd do one last check. I am also interested in any other mods people have done to these columns to beef them up or make them more robust for autocrossing. I have seen them cut off and had u joints put in bit I thought that was mainly to get the shaft around headers. Here's an example of what I mean on the year one bandit. So, anyone know of a rebuild kit?
![]() Sent from my iPhone using Tapatalk Last edited by Schroeder; 08-15-2016 at 07:08 AM. |
Anyone?
Sent from my SCH-I545 using Tapatalk |
There is nothing you need to do to make them better. You can put new bearings in but that is about it. They are good columns. If you don't have any problems now don't worry about it.
Any rebuild kits anywhere for a new boot and bearings, clips etc?
I have a tilt column out of a 74 ta and want to put it into my 79. I know the wiring is different as is the output shaft. but my problem is the shaft that holds the steering wheel has a good bit of play in it. the bearings are still intact what else should I look for?
you call yourself HARDCORE but are you truely hardcore ![]() |
![]() Quote:
Example: https://www.summitracing.com/parts/c...4MEaAhZc8P8HAQ Hope this helps. Britt
1975 Firebird / 1970 4" stroke 400, 6.800" Rods, 87cc Edelbrocks, XR-288-HR roller cam, Harland Sharp 1.5 roller rockers, Edelbrocks Pro-Flo4 port fuel EFI, Super T-10, 3.73 Posi. |
That kit is a direct fit?
Sent from my iPhone using Tapatalk |
There are 3 torx or inverted torx bolts for the upper bearing housing support that commonly loosen up. You will have to remove the steering wheel, lock plate, and turn signal switch for access,
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
There are 4 torx bolts/screws...requires E9 socket.
Read my article for tilt column rebuild: http://www.buickperformanceclub.com/...lumnwobble.htm Same column design from 1970-1994 for GM/Saginaw and Jeep/Chrysler. Email me direct if you need parts/help GS@BuickPerformanceClub.com |
