Old 07-03-2016, 05:48 PM
455hota's Avatar
455hota 455hota is offline
Default Trunk Lock to Tail Panel Gap?
I worked on the trunk lock and tail panel today.
I am questioning the gap from the front face of the trunk lock cylinder to the hole in the tail panel.
From the pics above, with the key inserted in the cylinder, the circular edges of the key are very close to the tail panel. I am worried about paint being scratched.
Does this gap appear to be normal? Is this the same on your Firebirds?
I did use a thin gasket to seal the trunk lock assembly as per the assembly manual. I also used washers on the 4 tail panel mounts (from the outside) as per the assembly manual.
Even if I remove the washers, the tail panel is already up tight to the body immediately above the lock cylinder.
Can anyone confirm if I am being overly OCD (as my daughters tell me), or do I have something wrong in the installation?
...Steve T.
"Resurrection of a 1970 Trans Am" Blog
www.455hota.wordpress.com
1966 GTO 4 speed Hardtop Alabama car (Marina Turquoise w turquoise interior)
1970 TA 4 speed Canadian car (Lucerne Blue w bright blue interior)
Old 07-03-2016, 06:23 PM
Transamric's Avatar
[QUOTE=455hota
I did use a thin gasket to seal the trunk lock assembly as per the assembly manual. I also used washers on the 4 tail panel mounts (from the outside) as per the assembly manual.[/QUOTE]
I've seen quite a variance in the depth to the lock cylinder face too. I would space the lock cylinder further back to reduce the gap.
Old 07-03-2016, 06:36 PM
Norwood's Avatar
Norwood Norwood is offline
Never had a problem with one but the gap should be zero
Old 07-03-2016, 07:45 PM
lfdsteve's Avatar
lfdsteve lfdsteve is offline
I ended up cutting my trunk keys edges down so I didn't mar the pAint. Not sure why it went together that way on my 71 but gave up trying to correct it and cut the key. Will be waching with interest.
Steve
462 Yc Block, zero deck
Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR
Comp Hyd-roller cam,roller lifters,springs ect.
236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6
Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut
Powerjection3,T2 manifold, Try-y’s
Flowcooler water pump.
71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire.
17x9 YO Honeycombs with Nitto 555's
Old 07-03-2016, 07:55 PM
455hota's Avatar
I think that will be my solution as well.. Cut down the key edges.
I have taken in all apart and looked at it very closely. With just the lock cylinder slid over the studs, and no gasket, the gap is still there. It is not a question of shimming, as that would make the gap wider.
I have an old lock cylinder and I removed the stainless cylinder cap. I pushed this through the hole in the sheet metal and the gap is still there, The flange on this cap bottoms out and does not allow the gap to get smaller.
The only way I can figure to eliminate the gap, would be to use a block and a hammer and physically move the metal surface out board to reduce the gap.
This would have been much easier when the car was still in primer, and not all finish painted.
Time to walk away and ponder options....
...Steve T.
Old 07-03-2016, 08:33 PM
cnc's Avatar
cnc cnc is offline
http://forums.maxperformanceinc.com/...d.php?t=771091
This is a great idea from Scarebird ....wish he would have made a run I would have been interested....I did briefly talk with him but it was thought that there would not have been enough interest possibly IIRC
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 07-03-2016, 09:12 PM
Transamric's Avatar
Sorry about my "shoot from the hip" response there. Forgot the cylinder bolts on from the inside, not the backside. Maybe next time I'll get one right!!
Old 07-03-2016, 09:31 PM
72projectbird's Avatar
72projectbird 72projectbird is online now
My 71 is the exact same way. I messed with it for a little while, got nowhere, and left it just like how yours is.
I don't open the trunk much, so it doesn't bother me.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
Old 07-04-2016, 02:08 PM
455hota's Avatar
After sleeping on the problem, the solution for me was to file down the trunk key edges to give me a little more clearance. It worked out nicely,
I can only figure, I have a lot more paint thickness around the tail panel key hole (primer, base, clear), probably a lot more than the factory lacquer that was on the tail panel originally.
Anyway onto the next issue....
...Steve T.
Old 07-04-2016, 03:12 PM
Formulabruce's Avatar
I use a cheap MES remote ,( California) and my keys Never touch my doors or trunk. Its easy to just do the trunk with No mods to the car aside from a relay behind the glove box hooked to the trunk release switch.
Old 07-06-2016, 07:32 AM
TTOP350 TTOP350 is offline
Yup, I'd think a remote (glovebox) trunk release would be in order and only use the key for backup.
http://www.fquick.com/garages/viewga...ewimg&id=74990
"You people have stood in my way long enough. I'm going to clown college."
-Homer Simpson
Old 07-06-2016, 04:51 PM
dadsformula dadsformula is offline
I cut my keys down as well, but I wonder if the original Keys had a longer
distance between the working end and the grip end. If that was extended
even an 1/8th of an inch or so, this is a non factor. I don't have an original
key to check, but it is possible. The thickness of the Fiberglass panel is the
constant on this, and could very well have required a longer Key.
Old 07-06-2016, 06:49 PM
455hota's Avatar
I thought of that possibility also. But I do not have an original key.
Can someone post a pic of an original trunk key with measurements?
...Steve T.
Old 07-06-2016, 06:50 PM
Norwood's Avatar
Original key.
Old 07-06-2016, 07:52 PM
Bentwheelbob's Avatar
Two pictures. Original old key and new key. In that order.
Old 07-06-2016, 08:40 PM
455hota's Avatar
Thanks for the pics Norwood and Bob!
I can tell that both your cars have almost no gap from the back edge of the tail panel key hole to the front face of the lock cylinder. That is why your keys set out nicely away from the tail panel painted surface.
Mine has a gap of nearly 1/8", causing my key to "bury deeper into the hole on the tail panel.
The other idea I had, was to disassemble the whole area again and using a socket and a rubber hammer, try to tap the metal hole in the body outboard 1/8". Obviously this would have been easy when we were doing the body work, so now I am a bit nervous.
https://goo.gl/photos/y7Ah7sw9ELZSDEA16
You can see I would have a lot of disassembly to get back to the sheet metal area. I am not sure on pounding with the tail panel in place!!! Maybe shaved keys are ok!!!
...Steve T.
Old 07-06-2016, 08:50 PM
I would pull it apart and fix it, but I suffer from OCD.
Looks like Norwood's die cut lettering is crooked....
Old 07-06-2016, 09:25 PM
Steve, is the fiberglass tail panel the original one or a replacement?
On my 73 TA I had to replace the panel, and the new one looked like that.
It had a big gap between the key lock and the panel.
Old 07-06-2016, 09:39 PM
Norwood's Avatar
I would fix it as well... Bob you made me go and look and its totaly an optical illusion. Mine are supposed to be diecut but I don't think yours should be.
Old 07-07-2016, 07:34 AM
455hota's Avatar
When I got my project, I received three tail panels in total. They were all GM original pieces. This one happened to be the best of the three tail panels, and of course I sold the other two already!
Question, do you think the metal area around the lock hole, could be bumped outward 1/8" SAFELY with everything assembled as is? The tail panel is my concern. I could loosen the 4 nuts, and loosen the tail lights, so the panel has some wiggle room.
Any thoughts?
...Steve T.
