Old 03-11-2016, 11:25 AM
Joe37 Joe37 is offline
Default help identify balancer/damper
I have this balancer I removed from an engine that was never started due to water setting in the cylinders. The engine was built in the mid 90's possibly in California. No marking numbers or identifying features.
It was black anodized at one point but became rusty from setting. It fits the late engines and is direct size replacement, pulleys bolt right up and align. Timing mark is dead on also. Weight is 11 pounds. Heres the odd part, its solid steel, one piece, machined form a solid blank. I can e-mail someone pictures if you want to see it or post them, I don't have any picture accounts.
Joe Hand
Old 03-11-2016, 11:29 AM
Send the pic to me:
johnta1@wallaceracing.com
Old 03-11-2016, 12:57 PM
AC445 AC445 is offline
Default Balancer
Hello,there was a guy from around Cleveland that set up at Norwalk years ago.I believe his name was Larry. He was selling his own design solid balancers as well as IV and V stuff. I think his company name was Arrowhead Auto. I hope this helps.
Old 03-12-2016, 08:11 AM
Here are the pics from Joe:
ID:	423425   Click image for larger version
ID:	423426   Click image for larger version
ID:	423427   Click image for larger version
Old 03-13-2016, 03:54 PM
gtofreek's Avatar
gtofreek gtofreek is offline
Fluiddamper maybe?
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 03-13-2016, 05:30 PM
tom s tom s is offline
If a fluid would it not have Some kind of hipo numbers on it?Tom
Old 03-13-2016, 05:45 PM
I would think so.
This is a solid piece of metal I think?
(no dampening)
Might be good for a belt drive blower?
(could use a factory pulley and blower pulley)
Looks nicely made though.
Old 03-13-2016, 08:29 PM
It's solid, all the way through! If someone thinks they can use it, let me know.
Joe
Old 03-14-2016, 10:01 AM
taff2's Avatar
taff2 taff2 is offline
If it's solid then it can't possibly do any harmonic damping, it's just extra flywheel weight along for the ride!
Old 03-14-2016, 10:49 AM
That's why I said it could be used on a belt driven supercharger/blower.
Most of them don't use a damper, the belt takes most of the harmonics on them.
Old 03-14-2016, 02:13 PM
I pulled it from a Macho T/A , last of 8 turbo cars. I just can't imagine why someone thought adding this was a good idea.
What would happen to the engine without a super charger? Would a crank stay together?
Joe
Old 03-14-2016, 04:20 PM
77 TRASHCAN's Avatar
The "light duty" 400's in the last 2-3 (?) years of production had a solid hub with no dampening ring.
My 77 solid hub 400 has 102,000 on it, and has been on a stand for a long time because of a flat cam lobe...
Shut it off
Shut it off
Old 03-15-2016, 07:04 AM
taff2's Avatar
Yeah,I've got a solid hub left over from my '59 389 engine, I kept it just in case I ever decided to build a mild blower engine.
