Old 12-28-2015, 12:15 AM
cp325 cp325 is offline
Default 1972 rear window DEFOGGER
anybody have a pic of the defogger and dash switch? also what other GM cars had the same unit or what would interchange.better yet anybody have the setup they want to part with?
Old 12-28-2015, 03:04 AM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
Here is a picture of the blower motor grill on the package tray. It was a common unit used on many GM cars throughout the 1970's.
The dash wiring harness is partially wired from the factory. There is a single blade connector above the driver's side kick panel. The control switch connector is behind the cigarette lighter. All you have to do is run a single wire with the proper Packard Series-56 terminal connectors from the kick panel to the package tray. The blower motor grounds to the body with a self tapping screw.
1971 Trans Am 455 H.O. - Cameo white
1982 Recaro T/A 305 - Black
Old 01-27-2016, 05:28 PM
dadsformula dadsformula is offline
Was the Toaster style defroster available in 72? I have this on my 73 rather than the
blower set-up and it's shown on my PHS, but curious what the first year was for this
option.
Old 01-28-2016, 12:40 PM
4birds's Avatar
4birds 4birds is offline
Default 1972 Pictures
Here are 2 pictures of the 72 Defog switch and package tray grille.
Name:	72 switches.jpg
ID:	419367   Click image for larger version
Name:	72 rear defogger.jpg
Old 01-28-2016, 05:04 PM
are all the early 70's gm defoggers the same?
Old 01-29-2016, 01:30 AM
giles's Avatar
giles giles is offline
No, '70, like in many things, is unique. Same switch but the blower motor, package shelf and cover are different than '71 & up. The 70 opening and cover is narrower (front to back) and wider (side to side).
Old 01-29-2016, 04:03 AM
AkCamaro AkCamaro is offline
I have a spare rear de-fogger that I pulled from a 73 Grand Prix. It's the same as the one in my 73 Trans Am. It is red/maroon though. I could part with it if you still are in need of one.
Old 01-29-2016, 11:32 AM
marxjunk marxjunk is offline
71 up is generally the same and interchanges...70 was the last year for the metal grate and then went to plastic. Later about 76ish the motor assy changed..the housing grew..but it still works.
the 71 up motor and grille are not hard to get..its the harness and switch and its almost impossible to get by themselves..
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 02-02-2016, 06:25 AM
what do you want for it?
Old 02-02-2016, 06:26 AM
oops! what do you want for it?
Old 02-02-2016, 07:57 AM
TTOP350 TTOP350 is offline
Its been quite awhile since I've seen it but I think my 73 rear window defoger switch has a little green light on it.
The car has electric rear defrost.
http://www.fquick.com/garages/viewga...ewimg&id=74990
"You people have stood in my way long enough. I'm going to clown college."
-Homer Simpson
Old 02-03-2016, 03:40 AM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
couple pictures of the 70 style blower motor. and yes I know grille is sitting on backwards, LOL.
Name:	78 TA pics 011.jpg
ID:	419838   Click image for larger version
Name:	78 TA pics 010.jpg
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
Old 02-04-2016, 07:58 AM
Here is the spare one I have. How does $75 shipped priority sound?
Old 02-04-2016, 01:24 PM
good working condition with wiring?
Old 04-11-2016, 07:54 AM
still looking for the dash switch.need the 3 prong,high/low.thanks
