If you restrict bi-pass coolant flow at heater core and intake to timing cover, forcing more coolant through the radiator. then clearance the divider plate to water pump, you wont need a fan except for stop and go. IMO.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk Last edited by Blued and Painted; 07-06-2015 at 12:27 PM. |
Restrict bypass
What do you mean by "restrict bypass coolant flow at the heater core"? Are you saying to block off the water going to the heater core altogether?
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
This is a Hayden 2747. 1st picture is the stock setting. 2nd picture is rotated to the right, CCW, which I believe shuts the valve right away. Is this the way to go? 3rd picture is rotated clockwise, to the left of stock.
When the coil is heated, in the 3rd picture, it rotates CW, doing nothing as it moves CW away from the tang. It's not as clear as the article say it is. What's the answer? Tony
my favorite place in the world a nice smelly garage |
BITD i blew a heater hose in my street car around the 1000 ft mark at Commerce. It was dark. Everyone was mad.
Later i replaced my already new hoses, found a pipe plug, drilled a .250 hole in it and screwed it into the heater hose @ the head nipple. Note/ some nipples are already restricted. This takes pressure off both hoses and the heater core. Dont confuse this mod with the race guys where coolant is plumbed back to the front water crossover and on to the radiator. Factory configuration, coolant goes back to the water pump by-passing the radiator. Then next time the intake is off, tap and restrict the bypass to timing cover. IMO/FWIW.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk Last edited by Blued and Painted; 07-07-2015 at 12:01 PM. |
Many aluminum intakes need the front water crossover opened up and gasket matched in the same manor as intake runners.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk Last edited by Blued and Painted; 07-07-2015 at 12:03 PM. |
Old Tin Indian - Your 2747 is a little different than mine. You could rotate CW or CCW 180 degrees to get a different setting. Maybe that is correct and maybe not - don't know. But my 2747 does not have a slot cut into the 180 degree opposite tab so I'm forced to try either if the two changed settings you show. And I'm with you in that neither is likely to work as the tang on the coil is not restrained in a slot. Move it one way and the coil expansion will only change the coil length and not move the valve. Move it the other way and it may move the valve but will not return the valve to the cold position. Apparently the article only applies to Eaton clutches. Dang - I wanted to try it.
http://forums.maxperformanceinc.com/...od+heater+core
I recalled reading this a number of years ago.
-- James Work '67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake." '75 Formula 400 - Daily Driver - Running with my Home Built 455 and TH400 Details here: http://forums.maxperformanceinc.com/...d.php?t=588372 |
Yes the brass cores will leak if "abused". I learned after a couple of changes back in 64 and 65. If you rev it high with the thermostat closed (i.e. it's cold and the car wants to stumble with the choke still closed so you rev it and dump the clutch to get going) the pump pressure will blow the heater core. Back in the day Olds had a service bulletin listing an Olds part number for a restrictor nipple at the manifold. I put one in replacing the 90 degree bent pipe that Pontiac used. Looked strange but it worked. The hole drilled in a piece of round stock and inserted in the hot hose would also work but back then I didn't have good access to the tools to do that. And had a buddy working at an Olds dealer so that was a cheap easy fix. No more blown heater cores.
thanks for replying pfilean. i'll probably put it back in the center and massage the divider plate a little more. i think i have it set at around .050" impeller to plate. i'm going to bring it down to .025-to-.030". this is so frustrating.
by the way, love the bubble-top. tony
This modification made a believer out of me and you do not need to relocate the spring tab a whole lot, a little goes a long way. By moving the spring tab CCW about an 1/8" I dropped my cooling temps a least 10 degrees.
I popped the spring out and cut a new notch using a small cut off wheel to the left of original and reinstalled spring. At start up you can hear the difference with a slight roar. Tested during a hot day at the track yesterday with temps in the 90's. In the past while idling in the staging lanes my temps would creep close to 200 deg.'s. Never hit 190 yesterday with 185 T stat. Attached is a pic of my modification, not the clearest but hope it helps |
I thought I posted here yesterday but for some reason it’s not here? Anyway what I said was that when the spring is heated it will try to unwind due to thermal expansion and that’s the direction you want to turn it to get the valve to open sooner. Also, there is no preload on the spring or valve.
Alright I did some testing on this yesterday. This is on a Hayden Severe Duty clutch. If you lift the spring out of the slot you can turn it about 90 degrees (counter clockwise in my case) before you feel a stop and if you turn it back to the original position you can feel a stop there as well. So apparently mine has a 90 degree sweep valve. I placed the spring back in the original slot and got out the heat gun and the temp gun. At about 170+ F it had turned about 45 degrees. At about 200+ it turned an additional 10-15 degrees. I heated it up some more and it may have moved slightly but not much, never reaching the complete 90 degree turn. Keep in mind these are air temps not coolant temps. When it cooled I lifted the spring out of the slot and let it rest against the edge of the tab (counter clockwise). I hit it with the temp gun and the movement was the same plus the additional amount that it was offset by not being in the original slot. It did move nearly all the way 90 degrees to the stop when heated to 200+. When it cooled the valve stayed in the same position but the spring contracted and moved away from the tab leaving a gap as there was nothing to capture it there. I wondered if when on a running engine the fan rotation and clutch when cold would rotate the valve and return the spring to the resting location against the tab but I did not test this. Instead I made a little clip to retain the spring against the side of the tab. Hope that helps.
68 Firebird, trying a q-jet now. 434/10.5:1/997's/240-242 HFT/4L80E/2800 Yank/3.42's/ Vintage Air/ 13.0 @105 mph 70 Lemans, 350/350, A/C, mostly stock 14 Ram CC, 5.7 Hemi, 8-speed, 3.92 lsd 97 Trans Am, HPP Aug 2012 http://www.highperformancepontiac.co...tiac_trans_am/ ***Sold*** |
Very cool idea quicksilver!!! I like that.
Quicksilver I like your approach. Great thinking. Keep us posted on how it helps (or not) on the road.
Quicksilver - how did it work?
Inconclusive. I dont have any cooling problems with the car moving, rather my temps creep up idling with the A/C on and I just dont think this is the fix. I've been running a 180 t-stat to see how my carb and intake like that but if/when I go back to a 160 I think that would be when I would see an effect from this mod.
#38
The mod worked for me! Temps went from 190 to 170 just from the spring relocation. Here's the play by play:
http://forums.maxperformanceinc.com/...664082&page=21 |
