New Power Plant
Here's something I'm putting together.
Now I have to make a decision -- What car to put it in. GT. |
And some more.
GT. |
And there's more.
GT. |
And the last two.
GT. |
Let me be the first to say.....Very cool I'm an N/A guy myself, but always had a thing for BIG wind machines sticking through the hood. Best of luck with it.
I see that is a 5 bolt motor mount block. Can you tell me what the date code is and the casting number of that 2 bolt main block. It is a 400 3" main block?
Thanks |
Pull the oil pan back off and take the Windaus tray off before it takes out the motor.
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
X 2
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
agree...that style (factory piece) has caused more issues than they resolve... get something better!
Is that factory cast connecting rods ?Bill C.
Checkered Flag Machine & Ceralli Competition Engines Racing engines and induction development http://www.checkeredflagmachine.net/ |
Hmmm... maybe its a "557" casting as well... seems caps look small and maybe the bore under-cuts above dowel area too... I see 4 eyebrow pistons as well.
Perhaps this is only a mock-up? |
Factory windage trays suck? Can you elaborate on problems that can cause and what will be better instead? Thanks
The 3/4 and full length trays are made from a lighter ga steel than the #5 455 3/4 tray. The tomahawk would be a better alternative,since its made from a heavier ga than the #5 or stock tray. I prefer leaving it off and use a baffled pan and or a scraper. |
What is all that white stuff around the rods caps??
LIFT HEAVY, LIFE IS TOO SHORT TO BE SMALL! |
At 8 psi with a turbo I hurt bearings in a stock bottom end, same pistons, trw forged. compression will have to be below 9 to be safe. I had a detonation issue.
What is that white stuff on the rods? |
GT's been busy! Put it in the wagon! Hee, hee, hee. Hope you're having a good winter!
Tony |
The motor is a 1975-400, 988 casting and 60 over TRW's.
The white stuff is a white moly grease for engine assm. It's pretty good stuff and stay's on the bearing surface and don't run off like oil will over a period of time. I got a picture of it here And you can get it at your local NAPA. Yes them are cast rods and a set of 4X heads that someone Ported for some reason unknown to me but they are the big chambers so It work out for me, The compression is 7:87:1 it's a 8.71 blower With holley carbs that are boost referenced and nitras injected. I punished this motor with n20 for about 5 years and didn't hurt it. It's pretty tuff so I thought I would throw the blower on it. This is about the most cheapest build and the lightest as for lite duty parts as can be. LOL If you see a big glow over in Mich. you'll know what it was. The blower pulley tooth count is 59 and 61 does anyone have a percent of what this might be and maybe the boost it could make. This stuff is new to me and if I like it I'll build a good motor for it. GT. |
You will be safe with that low compression, I now a turbo guy who has mostly stock stuff running 12psi for 5 years. ARP bolts would be nice though! It will be fun.
With those factory cast rods in there I would cringe and my ass would pucker every time I got on it. It may be a budget build but all for naught if a rod puts a window in the block.
Tim Corcoran |
