Tapping the front oil galley plugs
Anybody remember what size pipe tap it takes? Do I have to size the hole with a drill first or will the right size tap go right in?
Robert 69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always ) http://youtu.be/eaWBd3M9MN4 |
3/8 NPT No drilling needed. Don't tap too deep as it is possible to block the oil passages if you do. You'll want the plugs about flush with the face of the block.
'68 Firebird 463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14 Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 2022 - 10.13 @ 133.07 9.93 run - https://youtu.be/hII0_UlYM4U |
Thanks.
Firebob, not trying to be a smart ass but it is gallery. A galley is a kitchen.
1969 GTO 4spd. Antique Gold/black, gold int. 1969 GTO RAIII 4spd. Verdoro Green/black, black int. 1969 GTO 4spd. Crystal Turquoise, black int. 1970 GTO 4spd VOE Pepper Green, green int. 1967 LeMans 428 Auto. Blue, black int. |
Yup 3/8-18 NPT. Here is a pic of mine getting the deed. I did not drill it out first but it was tight and slow going. Just be very careful and you should be ok. Also worth noting that there are a few different thickness pipe plugs available depending on where you get them. If I remember right my frost plug kit came with a nice thin pair that I used. I had gotten some at the hardware store but they were much thicker and stuck out of the block more. I also added a hole for chain oiling to one of them. Not really necessary but figured what the hell.
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi. Everything installed, fired up and tuning has begun! |
Make absolutely sure to check the depth of the plugs, you may need to grind a little of the back to keep from blocking off the oil passages in the block. I also put a .030" hole in one of them for some additional spray on the timing set. There are no negatives from this modification and minute or so during the build.........Cliff
Make sure you rifle brush the all the passages THOROUGHLY, to get all the shavings out.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust My webpage http://lnlpd.com/home |
Use cutting oil too- it helps a lot!
John IG: @crawdaddycustoms YouTube: https://www.youtube.com/channel/UCK9...Nc_lk1Q/videos |
Thanks for all the advice. Galley/gallery, WELL I'M COOKIN NOW BABY!!!! I thought a gallery was some you shoot little ducks in.LOL.
Is there a torque spec for the 3/8" NPT oil gallery plugs? I have never seen one,and its not in any books by Rocky or Jim Hand.
My guess would be 25-30ft/lbs. |
That's probably good. I just screw 'em in good and tight, but not too tight, and call it good.
The Following User Says Thank You to JC455 For This Useful Post: | ||
I usually loctite just about everything in these days anyway. Just for a little bit of added insurance.
I agree about being careful how deep you tap and then the thickness of the plug.
I was inspecting my 1978 400 W72 block to see how far the oil gallery passages are from the front of the block. I did some quick measurements of each front oil gallery hole to see how far back the oil gallery passage is. . The driver's side oil gallery passage was approximately .4" from the front of the block. On the passenger side, the oil gallery passage was approximately .475" from the front of the block. (see pics). Others have reported their oil gallery passage was closer to front of block. So, i think it is a good idea to check. |
Or somewhere where you look at art!
Or where they kept the Peanuts (God, I'm old)
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
Everyone has nailed it perfect!!! Cleaning and the riffle cleaning brush a absolute must!!
I just redid a fellows galley plug area & he was amazed of what came out of the area. |
cruiser, check your PM.
Why is this mod needed?
Well if you ever rebuild, you just remove npt plugs and clean.. Easier to inspect block again, again and again.. No need to restake plugs after rebuilt and worry about them falling out..
Just a good thing to do like deburring the block..
