I need studs for cam housing
I need 5 of both the long and short studs for the cam housing so a total of 10 I know there Re only 2each originally but I am dressing up the engine with acorn nuts and want to get rid of the bolts
When you really do something right it's like you didn't do anything at all 1931 Pontiac 5 window coupe OHC6 powered 2015 GMC Yukon SLT |
Grainger &/or Fastenal both have good selections of double ended studs.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
might as well go stainless and use stainless acorn nuts too
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
I will try fasten all I didn't even think of them today there is one here in town
I already have polished stainless acorns
what is a cam housing?
Sits on top the head and house's the cam as seen in the pic
Or like this
Many times mistakenly referred to as valve cover.
AKA cam cover
No good at fastenall
What about carb studs with the right height I dont see why that wouldnt work.
The studs are 2 5/8 and 3 1/2 " long I think I found some from doorman that are a little long but I will shorten them
I stand educated - did not notice for OHC-6
http://www.summitracing.com/parts/arp-200-2403
If Dorman dosen't work maybe something like this might work. |
Too short
Really? if you check both sites online they have many sizes listed. Let me pull my bin and see what I have.
Found some...
GW,
I was able to come up with enough. Only one of the short ones is slightly longer but they all are straight and have good thread. If your interested how's $15 to your door?
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. Last edited by Jeff Hamlin; 02-08-2013 at 07:22 AM. |
Sound good Jeff pm me the info
