Old 08-06-2012, 09:17 PM
Terry Gartner's Avatar
Terry Gartner Terry Gartner is offline
Default Honeycomb Trim Rings
Good Evening,
I recently put a wider tire on my 72 car with 15" honeycomb wheels. But now I can't seem to get the trim rings back on. The tire is a P245/60, is there an aftermarket trim ring that will fit?
1964 GTO Auto
1970 GTO Ram Air III 4-speed
1972 Lemans Convert with endura option, 455, 4-speed
Old 08-06-2012, 11:30 PM
Matt Meaney's Avatar
Matt Meaney Matt Meaney is offline
with the wheel off the car, I let all the air out of it. then, pushed the tire away from the rim as best i could by kneeling on it. starting the clips where the tire was farthest away from the rim. it wasn't real easy, but i got them on by working my way around the wheel.
GTO71's Avatar
GTO71 GTO71 is offline
Default Trim Rings
They are very difficult to put on, as a kid I worked for Goodyear changing tires on every type of car one can imagine. The honeycomb trim rings are the most difficult you get three sides on and the fourth side looks like it is 3/4 of an inch too big. I would get a second person to help hold the rings in place while you massage it on the rim. A rubber mallet can help but be carful not to dent the trim ring. It is a pain in the butt. Lets just say I will never balance the tires again. but you can get it done trust me
Old 08-07-2012, 06:11 AM
74 SD455 Formula 74 SD455 Formula is offline
If I'm not mistaken in 72 a LeMans with the GTO option and 15" Honeycomb rim's the trim ring was not available as an option.I have a 72 GTO with it's original Honeycomb rims on it and I do not have trim ring's nor does it appear on my build sheet. Other than that Matt M. has the only way I know to put them on.
Old 08-07-2012, 07:46 PM
Yes, I think you're correct that they did not come with a trim ring. But, I like the look of them and I already have them. I like the idea of letting the air out, I'll give it a try, and don't worry. I'll put air back in.
1964 GTO Auto
