Old 04-02-2012, 07:24 PM
henesian henesian is offline
Default Pontiac Holley Street Dominator Intake Fit and Impression on a nearly stock 400
Hey, so like the title says, I found a Holley Street Dominator Intake for a Pontiac 400 on Ebay for $130 in extremely good shape, and decided to replace my existing Edelbrock Performer intake for it. The car is a 1976 Trans Am with a low compression smog-legal 400, 2:73 gears, T-350 with 2600 rpm stall and a Q-Jet on top(72 primary jets, stock primary metering rods, CV secondary metering rods, tight secondary air valve, P hangers) and a crane 272/272, 216/216, .454/.454 lift cam. Also running stock log exhaust manifolds with a 2.5" system. The car is an AutoX car, not a drag car.
It doesn't lose anything in bottom end to the Performer, and it is a way more efficient manifold, and takes less throttle to keep the car cruising at the same speed. I actually picked up a couple miles per gallon too. In my 80 mile drive back to Sonoma State from home, I usually use about 4-5 gallons while going 60-65, this time, I was going 70-75 and used a little less gas, with the same amount of traffic and retarded drivers. Even with stock exhaust manifolds choking the motor off at the high end, it still has more top end than the Performer and revs alot freer and makes the torque converter work a lot better, which is especially good when coming out of the exit of a turn. Also, the motor sounds alot smoother, and beefier. The only problems I had were that the positioning of the throttle bracket posts on the manifold were a tad far back for my stock 76 Tranny kickdown and Throttle cables, so I had to fanagle a set up with the Edelbrock throttle adapter.
I know that people have been questioning whether this is a good manifold or not for a long time, and are very scared of single plane manifolds not having enough low end. I can say for sure that this manifold easily covers the Edelbrock Performer for low end, and rises above it as well. However, I don't know about the Performer RPM or the Torker 2.
ID:	280401   Click image for larger version
ID:	280402   Click image for larger version
ID:	280403   Click image for larger version
ID:	280404   Click image for larger version
Old 04-02-2012, 08:21 PM
harry k's Avatar
harry k harry k is offline
Send a message via AIM to harry k Send a message via MSN to harry k Send a message via Yahoo to harry k
nice experiment for you
confirms what our master Holley guru Tom V. has stated all along & not too long ago in another popular thread ,
which what was Holley's goal to build that intake manifold !
http://www.hkmotorsportsdynoshop.com/
someone who thinks logically is a nice contrast to the real world.
http://www.youtube.com/watch?v=3FfKVVZW1-Y
Old 04-02-2012, 08:34 PM
Thanks. Do you happen to know the name of that thread?
Old 04-02-2012, 08:41 PM
http://forums.maxperformanceinc.com/...reet+Dominator
Old 04-02-2012, 08:59 PM
harry k's Avatar
here is the reply #45
http://forums.maxperformanceinc.com/...9&postcount=45
exact part as your claim or tested
Holley Street Dominator was designed to be 3% better everywhere vs a STOCK Pontiac Aluminum RA-IV Intake manifold.
Old 04-02-2012, 09:07 PM
Thank you both for the links.
Old 04-02-2012, 09:09 PM
Half-Inch Stud's Avatar
After careful review, I think the 76 T/A autocross car wil run super, with any 4bbl manifold, particularly a dual plane. such Thecombo can be responsive, and have a great pedal feel.
If you double the engine HP, then the manifold choice will be a useful variable. Ability to retain the pedal feel while making HP is a common goal.
("auto-correct text" on me iPad has caused me to edit some weird words out)
Old 04-02-2012, 09:41 PM
ITSBACK's Avatar
ITSBACK ITSBACK is offline
Wow, I just finished reading that battle. Whats the answer?
Old 04-03-2012, 02:29 AM
1971WARBIRD's Avatar
1971WARBIRD 1971WARBIRD is offline
i'll take a shot.
stock vs stock, it will out do the stock pontiac intakes.
modify the stock intake( it is not stock now) and the modified stock intake will out do the stock Holley.
modify the Holley and it will keep up with the modified stock in the right engine car combo. car, weight, heads, cam, intake, carb, trans type, converter, tires, gears, you name it, all have to work together to get the bast out of any combo.
the main thing is stock vs stock. you can modify the daylights out of somethings to get them to work. look back where some people took early torquer intakes and cut them in two peices and welded the 2 rears together to make a modified race intake.
FREEDOM ISN'T FREE
BUT WORTH FIGHTING FOR
Old 04-03-2012, 09:38 AM
ITSBACK's Avatar
OK, this thread catches my attention because I am building a 428, not crazy maybe 425-450hp and I have a modified Holly Street Dominator that was port matched to the heads by Paul Spotts. This is a street car mostly and some guys dont like the single plane for street use where others say they run just fine. Just trying to use what I have to get rolling.
Old 04-03-2012, 11:43 AM
You should try and run it. The fact that it's port matched is fantastic.
Old 04-03-2012, 12:28 PM
rad400 rad400 is offline
ITSBACK I would run it and henesian I would keep with it. I would like to try one myself.
Conrad
79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers.
Old 04-03-2012, 01:09 PM
ITSBACK's Avatar
I am going to run it.
Old 04-03-2012, 04:26 PM
Tom Vaught's Avatar
Boost Engineer
Herb Adams (a former Pontiac Engine Engineer LOVED the Holley Street Dominator Intake and used it on all of his FIRE-AMs.
http://www.firebirdgallery.com/fireamlot1.htm
http://www.pontiacsonline.com/Herb%20Adams.htm
Tom Vaught
Old 04-03-2012, 06:52 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
Tom Vaught
Herbie knew his chit!
Old 04-03-2012, 08:22 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
It was the only intake Herb had in his catalog. I lived in N CA and picked up some of his suspension pieces at the shop in Monterey at the time and saw the white can at Laguna Seca road course.
Skip Fix
