Old 11-04-2011, 03:30 PM
triplets triplets is offline
Default ANYONE HAD PROBLEMS WITH AMES TRIPOWER TOP RAD HOSE?
I just installed my new ames tripower top rad hose it seems short it is kinked at the neck?
Old 11-04-2011, 03:59 PM
Dick Boneske's Avatar
I don't remember where I got mine, but it's too long and will have to be trimmed to remove the kink.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 11-04-2011, 04:13 PM
elefantrider's Avatar
elefantrider elefantrider is offline
I don't remember where I got mine but I have the same problem. Had to trim and it is still a little kinked. Who makes the best-fitting one?
Old 11-04-2011, 04:56 PM
bill ryder's Avatar
bill ryder bill ryder is offline
Default GOOD STUFF
You need to try Jeff Ashen, from Davie, Florida. He does his own hoses and has "originals and pictures of originals" to do the stamping. Hose texture is VERY similar to NOS. He has done several restamps for me. He also sells on EBay as pacecarjeff. Posts here,too, every once in a while. Give him a look. http://forums.maxperformanceinc.com/...+radiator+hose
Old 11-05-2011, 01:49 PM
Thanks my hose is way to short it fits but is way kinked.(Its not the first time i heard that) I cant believe that ames hasent had any complaintes.Not to bitch but it is hard enough to find these old cars then come up with the funds to work on them almost every part you get something is wrong. I do not see it flowing coolant correctally .Anyone have a contact source on jeff ashen.I cant find him.
Old 11-05-2011, 04:18 PM
Pacecarjeff's Avatar
Pacecarjeff Pacecarjeff is offline
Thanks Bill - Love your car.
Can someone post some pictures of what problems you are having with the other vendors hoses?
I make all my hoses one at a time special order, and have never had any complaints - but you never know?
Which hose number are we talking about?
Here is my website ---> www.pacecarjeff.com
www.pacecarjeff.com
Old 11-05-2011, 04:52 PM
66Post's Avatar
66Post 66Post is offline
Too long, had to cut 2-3 inches off the radiator side, other than that satisfied.
Old 11-05-2011, 04:58 PM
Too long is always better then too short.
www.pacecarjeff.com
Old 11-05-2011, 07:08 PM
66Post's Avatar
Wink
Roger That!
Old 11-06-2011, 02:06 PM
michaelroy's Avatar
michaelroy michaelroy is offline
Default Rad. Hose
Just installed one from Ames last week. It was perfect. No trimming no kink. Probably one of the few times something was just right.
Old 11-06-2011, 06:15 PM
Hose#9779581 Do you have any 65 tripower top hoses in stock? Im in hollywood fl.
Old 11-06-2011, 07:18 PM
bill ryder's Avatar
Default Stock hoses
http://www.pacecarjeff.com/ Try this.
Old 11-07-2011, 08:18 PM
I just checked the py catalog it shows 3 different water necks for the 1965 tripower.Whatsup with that mine curves to the drivers side?
Old 11-07-2011, 08:41 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
I had issues when I built my car ('66 3x2 + P.S.). I ordered 3 different hoses and they all fit poorly. I ended up cutting it in the middle and made it work. Unfortunately I cut it a little short and noticed a few weeks ago that the alternator fan has been rubbing on it. I just ordered another hose and when I got it, I remembered how much cutting I had to do to fit it.
I shouldn't have to do it on a 'proper' hose. I have a Griffin Rad, but the outlet is in the same spot as OEM. If I route the hose the way it should be, then it kinks behind the alternator.
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
Old 11-08-2011, 05:02 PM
Lightbulb
I have a 66 water neck that curves to the drivers side duh.I ordered the correct strait water neck from py today.Thanks for all your help guys.
