Old 03-03-2010, 11:21 AM
MOJO Catalina's Avatar
MOJO Catalina MOJO Catalina is offline
Send a message via AIM to MOJO Catalina
Default TH400 Flex Plate, Bolts & Cover needed
I'm converting my '63 GP to a TH400 and need a few parts.
The trans I have is a '73 BOP and I need the flex plate, bolts, inspection cover, a dipstick and tube. They were supposed to be included but the guy I bought the trans from 'forgot' to bring that stuff the day I picked it up from the back of his truck behind the shop he works at and now 'can't find' those pieces. I've called and emailed him every few days for a few weeks but he keeps putting me off so...
Any of my Pontiac tribal brothers have a few pounds of scrap metal laying around that they can contribute to a fella who's down on his luck? I have a few sheckles to pay for the shipping...
Old 03-03-2010, 11:54 AM
Keith Seymore's Avatar
MOJO - I can't help with the parts, but can (as always) make a few comments:
I ordered a Pontiac flexplate out of the Jegs or Summit catalog. I don't remember now how much it was but it seemed pretty reasonable at the time (plus it comes right to your front door - and it's new!).
Re: flexplate bolts - I don't remember what size those bolts are but they are unique (a generic chevy bolt won't work). I ended up re-using the original flywheel bolts - which are too long because the Slim Jim flywheel is so thick - but used a hardened washer under the head of the bolt to keep them from poking through the back of the crank.
Dipstick - I couldn't get my TH400 dipstick (from a '76 Riv) to fit up in there. Ended up using a Lokar flexible dipstick with a homemade support bracket. It was a bit pricey ($100 or so) but seems to work well.
Inspection cover: I've been just running around without one.
After reading my note, you are free to use my dipstick tube (no indicator stick) but, as I say, I turned it every which way but loose and couldn't get it to snake through there.
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
Old 03-03-2010, 02:06 PM
K
Thanks for the comeback good buddy (shows ya how old I am...)
I'll check into that stuff. I guess I could grind 1/4 inch off the ends off my bolts.
Would that be enough?
Meanwhile, I'm still open for hand-outs if anybody has a whole heap of this stuff they just want to "git gonn" as they say here in the south.
Sometimes towed but never trailered!
Old 03-03-2010, 04:07 PM
stevep's Avatar
stevep stevep is offline
If you can find a trans pan/tube/dipstick from a 64 Eldo or Deville, it will solve your problem. It has to be from and Eldo or Deville as a Series 62 doesn't have a THM 400.
Old 03-03-2010, 05:24 PM
Probably - but I wanted to leave mine as they were in case [Hell freezes over and] I ever decide to put ole' Jim back in....
K
'63 Grand Prix
Old 03-03-2010, 10:20 PM
rontiac's Avatar
rontiac rontiac is offline
I'm not positive, but isn't there a problem with the starter on the 1963 and older blocks? I am under the impression that they switched sides in 1964. Not 100% sure though....
Anybody else know for sure?
http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=143670&dateline=12211  78868
1965 LeMans Post Coupe..............I'm not waitin for the undertaker....I'm lookin forward to the uppertaker!.....
Old 03-03-2010, 11:10 PM
MOJO's got that all psyched out already, but the short answer is: on '63 blocks the starter mounts to the trans bell housing - so - if you change to a newer trans you lose the location to hang the starter.
That problem is usually solved by adding an adapter/starter mount plate, which are available commercially or a person can fabricate their own based on the blueprint in Pete McCarthy's book.
K
'63 Grand Prix
Old 03-09-2010, 09:01 PM
chrisp chrisp is offline
Have a dipstick and the tube from a 1970 catalina 455 engine , 400 turbo trans , may have a converter cover .
Old 03-09-2010, 09:19 PM
I'll take 'em if I can afford the shipping.
If you'll send me a PM we can get it all worked out.
Old 03-09-2010, 09:20 PM
K
Which one of his books has that info in it?
Old 03-11-2010, 12:53 AM
ITSBACK's Avatar
ITSBACK ITSBACK is offline
I may have a flexplate for you. I can check on the shelf tomorrow?
Bill
Old 03-11-2010, 08:36 AM
Ponatiac Racer's & High Performance Handbook, which is the one with the black & white pictures on the cover.
It's on [what would be] page 49 (...for some reason there are no page numbers in that section).
K
'63 Grand Prix
Old 03-12-2010, 01:41 PM
heh, heh -
I said "Ponatiac"....
(wish we had an "edit" button).
K
'63 Grand Prix
Old 03-12-2010, 02:14 PM
Pontiac Racer's & High Performance Handbook, which is the one with the black & white pictures on the cover.
There. I fixed it for you.
Of course, I have the OTHER of Pete's books here.
The Torque Converter on this trans takes 3 bolts.
Is that typical?
ID:	199977   Click image for larger version
ID:	199979   Click image for larger version
Old 03-14-2010, 08:35 AM
[Have a dipstick and the tube from a 1970 catalina 455 engine , 400 turbo trans , may have a converter cover .] Yea or nae ? Tube is short unlike the one in your pic. Dipstick has the large tip on the end , easy reader .
Old 03-18-2010, 09:54 AM
Sounds like the one I need since my car has air.
Where are ya and how much$?
Old 03-18-2010, 08:41 PM
Send me a pm with your email , i will send pics. Thanks
Old 03-19-2010, 11:08 AM
gloryrestoparts's Avatar
gloryrestoparts gloryrestoparts is offline
I have a flexplate, the 6 bolts which hold it to the crank and 3 bolts which attach the torque convertor to the flexplate. they are from a 71 400. PM me if you still need them. Thx, Chris
http://gloryrestoparts.20megsfree.com/
1970.5 Pontiac Tempest GT-37
400ci 4bbl 4sp 3.90:1
12.73 @ 112.42 2011 Pure Stock Drags
12.71 @ 110.58 2013 Martin FAST/FS race
12.70 @ 111.74 2014 Pure Stock Drags
12.60 @ 111.66 2015 Martin FAST/FS race
1968 Pontiac Firebird 400
TH400/3.08 open
export car - factory heater delete
14.48 @ 95.86 w/ 2.14 60' 2018 Pure Stock Drags
14.47 @ 95.02 w/ 2.16 60' 2019 Martin FAST/FS race
Old 03-19-2010, 11:46 AM
PM sent.
Old 03-22-2010, 11:06 AM
Thanks, Will do.
