Old 10-28-2009, 11:30 AM
61catalinaguy's Avatar
61catalinaguy 61catalinaguy is offline
Default edelbrock p22 intake dual quad setup
Hello,i am looking for an edelbrock p22 intake or a complete dual quad setup with a p22 intake or just a factory carb setup without the intake for my 61 catalina.It currently has the original 389 10.25 compression motor.
Old 10-28-2009, 12:04 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
Just FYI, the Offy intake is closer to the original Pontiac intake than the edelbrock, and you can use the original style air cleaners with the Offy intake, you can't with the edelbrock.
Old 10-28-2009, 01:09 PM
Default 61 cat dual quad setup
Thanks for the info.Anyone have an offy intake?
Old 10-28-2009, 02:42 PM
tom s tom s is offline
there was a Offy in ebay last week.Tom
Old 10-28-2009, 08:22 PM
jdh421's Avatar
jdh421 jdh421 is offline
PM sent. I have a dual quad Offy I would sell. Jeff
1966 Catalina Convert
1968 Firebird 350
1969 GTO
1967 Bonneville 4 Dr Brougham 428
1967 Bonneville 2 dr
1959 Buick LeSabre 2dr
Old 10-29-2009, 08:00 AM
carbking's Avatar
carbking carbking is offline
We are out of the 2x4 Offenhauser manifolds, but this list may help you decide which Offenhauser will suit your needs.
Can help with carbs, once you obtain a manifold.
http://www.thecarburetorshop.com/Pon...emanifolds.htm
Jon.
Old 10-31-2009, 12:08 PM
Jerry H.'s Avatar
I have a '5162' that per Carbkings chart says it's for 61-64. But it is different from the one pictured in his chart. The water outlet is different. 61Catalinaguy, if you don't come up with one anywhere else, I would sell this one. PM me if interested.
Old 10-31-2009, 04:13 PM
there is a brand new one on ebay now.Tom
Old 10-31-2009, 04:47 PM
Default offy intake
I am looking at the one on e-bay too.
Old 11-01-2009, 02:09 PM
Jerry H.'s Avatar
Tom, can you post a link to the new one on ebay. I searched and the only new one I found was a high rise for 65-up, not a 5162. I want to compare a picture to the 5162 that I have.
Old 11-01-2009, 04:00 PM
Default offy intake
Hey everyone who responded to this add.I appreciate all the responce and i bought the intake off from e-bay from vintage auto and speed equipment.I do need some advice on carter carbs as far as the setup.
Old 11-01-2009, 06:34 PM
carbking's Avatar
Will be happy to discuss Carter carbs.
573-392-7378 (9-4 Mon-Wed central time).
Jon.
Old 11-02-2009, 12:00 AM
Jerry H.'s Avatar
I sent you a PM.
Old 11-02-2009, 12:07 AM
Jerry H.'s Avatar
I sent you a PM.
Old 11-07-2009, 01:01 PM
poison heart's Avatar
poison heart poison heart is offline
Send a message via AIM to poison heart
I went with dual 1965 Pontiac Carter AFBs. I have 2 spares for sale. One rebuilt and one not.
Here are the other 2 on my star chief
Robert Lewis
1959 Star Chief 4 Dr HT dual quad 389 4 speed
1962 Pontiac Plain Jane Catalina
http://pontiac-59.com/
Old 11-07-2009, 01:20 PM
Jerry H.'s Avatar
Not to hijack this thread, but Poison Heart, do you remember the Part # of that intake? The one I have looks exactly like it. It has '5162' on the underside.
Old 11-07-2009, 01:35 PM
This one has a part number of 5029 but it is not a 5029 intake. I have no idea how the part number was cast wrong into it. This intake is made to fit the 55-60 AND 61-64 heads. I'm not exactly sure which part number this intake should be but it does fit 55-60 AND 61-64 since this intake does have both coolant passages and is even shaped different than all other 5029 intakes I have seen. I didn't notice that it had both coolant passages and when I filled the motor up with coolant HUGE leak. hahaha
This one is a 5162 which I think came in low rise and a higher rise. I believe this one is the taller one.
That's on a '63 389. Notice how the front of the intake lines up with the 63 timing cover.
There's a 5161 intake with the low rise design. That's on a '60 block with 59 parts. Notice the bolt hole and water passage in the very front of the intake and how it does not line up with the 59 timing cover.
I hope this helps.
Robert Lewis
Old 11-08-2009, 01:07 PM
Default dual quad setup
Well,i just received my dual quad intake.It is a offy 360 equa-flow high rise manifold,part number 5707.It looks impressive and the box has 55-64 on it. I am going to call The Carb Shop very soon to get some options on carbs.Thanks for the info on carb numbers.When i learn to post picts on this forum, i get some picts soon.Jeff.
Old 11-08-2009, 01:16 PM
Jerry H.'s Avatar
I hope this helps.
After looking at your pictures, I went to the shop to look at my intake again. It is definitely a '5162' but it is a twin to the first one you pictured. It has the water outlet coming out the front, not out the top like the others you posted; and the later (65-up) intakes. It is a low rise intake and is missing the 'adapters' to mount the carbs.
Old 11-08-2009, 02:13 PM
Post a picture of it. Especially the bottom
Robert Lewis
