Tri-Power Tech 57-66 Tri-Power Talk
Old 11-08-2008, 01:28 PM
slowbird's Avatar
slowbird slowbird is offline
Default World's fastest tri-power
Well I think it is anyway. We almost got our 9 but not quite. We are done for the year maybe next year. Here is our fastest pass from a couple weeks agos
60ft 1.356
330ft 3.997
660ft 6.282
mph 107.06
1000ft 8.282
1320ft 10.005
mph 129.79
Not to bad for a hyd cam and tri-power, car weighs 3450lbs.
Old 11-08-2008, 01:32 PM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
id be happy to get my tripower car in the 10s when finished.......i think at 10.005 now thou you will already be in the 9s.
Old 11-08-2008, 01:41 PM
slowbird's Avatar
I should say that is without any kind of power adder also, all motor
Old 11-08-2008, 04:24 PM
bad69bird's Avatar
bad69bird bad69bird is offline
DAMN you were so close to getting in the club! Congrats! Very nice 60' too.
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs)
Old 11-08-2008, 05:19 PM
grandville455's Avatar
grandville455 grandville455 is offline
Wow ! Soooo Close!!!! U will be there in the spring!!!
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 11-08-2008, 05:50 PM
wrench's Avatar
wrench wrench is offline
DAMN, .006 Thats going to give you nightmares during the off season!! You can't get out one more time?? Great job. has there been a Pontiac Tri-power in the 9s??? Any video?
Old 11-08-2008, 06:03 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
WOW, almost 130mph and a 1.35-60'! Congratulations!! OK, so....is anyone faster than 11.70 and weigh MORE than 3860lbs with a Pontiac Tripower....and... rochester carbs and...iron heads,.pump gas? Give me something to shoot for. Post those Tripower times. -Jim
Old 11-08-2008, 06:09 PM
slowbird's Avatar
We have ran 131mph with a taller tire.
Our 1969 GrandPrix weighs about 4150lbs and runs 11.7s, with iron heads, pump gas, and of course tri-power. Pretty sure we can get 11.6s out of it. Both cars run Rochester carbs.
Old 11-08-2008, 06:51 PM
what comp and cam in the 69?
Darby
Old 11-08-2008, 06:52 PM
DiamondJim's Avatar
Sounds likeI need to hire you to tune mine! I am also hoping for some better times, I have made a few minor improvements. -Jim
Old 11-08-2008, 07:00 PM
slowbird's Avatar
The cam in the GrandPrix is a hyd roller that is 242-252 @ .050 and compression about 10.25:1.
