Getting ready to paint my frame on my 1970 gto convertible. This car will be drivin alot. Im thinking about Magnet paints Chassis Saver in antique-satin.
http://www.magnetpaints.com/Default.htm The car does not have to be original, I want it to last. What did you guys use? |
Seeing as how my '67 had rust on everything but the air in the flat tires, I've done everything I can think of to get rid of it and keep it from reappearing. Nearly every component that would fit into a blasting cabinet (and a lot that wouldn't) was painted with Chassis Saver afterward.
I wound up putting two coats on the front subframe and it looks as good now as it did a year and a half ago, although it is yet to be put back on the car. One thing Chassis Saver has in common with POR-15, though, is that it is UV-sensitive, and will turn to a light grey after prolonged exposure to light. What I plan to do is scuff it up and hit it with a couple of coats of Eastwood Extreme Chassis Black satin. I've read a lot of good stuff about it here and on other forums. Good luck! |
I had mine blasted and powdercoated black here locally at a shop that has a nice big blast room and a very large oven.
2006 GTO M6 IBM 525/486 1970 GTO Dude built 455, , Auto Convertible, Paint and Body Work by Prodigy Customs. |
Thats exactly what I used on mine, jsn. Theres some pics on my site of before and after.
A friend will help you move...a GOOD friend will help you move a body. |
I used POR 15, then top coated all visible parts with POR 15 gloss black top coat. Goes on nice and is tough stuff.
64 Lemans hardtop 4spd, buckets |
I used Zero Rust satin black. I got it from Len at http://www.autobodystore.com//altABS/home.shtml
Great product, great site and a great guy. Murf |
i used rust oleum black satin three years ago and looks like i just painted it.you can spray it on and thin it with acetone
I had my 70 gto sandblasted and powdercoated black and my 71 I used chasis black by eastwood both look great.
I used Master Series silver as a base with their satin black as a top coat.
I have several different products over the years. Zero Rust works very well for a 1k product. It and the Rustoleum are very easy to use. I have also used PPG DP-90 and Master Series.
My money talks to me-it usually says goodbye! |
![]() Quote:
Jack Ferris RestoRacing LLC www.restoracing.com Sandy, UT --------------------------------------------------- |
I used ppg dp epoxy.
http://www.1969supersport.com/047.html If your interested, all the information is on my website. Rob
"There are questions to be answered, and answers to be questioned" Jigs, sandblasting, shop, paintroom, rotisserie, pictures, little bit of everything. http://www.1969supersport.com |
I sandblasted mine and sprayed with por-15 and top coated with por-15 blackcoat.
It came out great and is real hard and tough. I seen my friend above 71 lemans frame after being powdercoated and that looks awesome. The only down side of the por-15 or any other paint is that it can be effected by brake fluid.I had a brake line go and it melted or bubbled the por-15.My whhel wells are powdercoated and they were not affected by the brake fluid. So,if i had to do it again,i would have powdercoated the frame.Other then the brake fluid,thepor-15 is tough and is nearly impossible to chip even if you hit it with a hammer. Here are a couple pics of my frame por-15. Also did the bottom of my car. ![]() ![]() ![]() ![]()
9.81 at 139.89mph 3400lbs Butler 468,11.3:1 comp,N/A,PUMP 93 OCT GAS! 370cfm butler eheads port matched victor 1095 king demon 4.30gear,th400 MICKEY THOMPSON DRAG RADIAL tire ![]() |
I highly recommend Bill Hirsch Chassis Black or Miracle Paint. I just shot my engine bay with Chassis Black this weekend and it lays smooth as silk with a super satin finish. Been in business 40 years with quality products. Go to their site or send me a PM...I rep their products.
Here's a pic of the engine bay. ![]()
Now stocking Bill Hirsch engine enamels and other chemical products 53 Chieftain "Herman" 55 wagon 72 Grandville |
Sand blast then DP90...
