Old 06-16-2007, 07:59 PM
70 lucerne lemans's Avatar
70 lucerne lemans 70 lucerne lemans is offline
Default crazy oil pressure
I was a little low at idle hot about 10-15 lbs in drive so I added a bottle of STP to my 15-40 Rotella cj-4 that already had a bottle of EOS, to thicken it up a little.I also adj.the lash on my solid cam.Now the pressure doesnt go below 40 lbs at idle.I cant believe 1 bottle of Stp could make such a drastic change.Any ideas?
Mark
1970 Lemans Convertible,462,6x-4, 234/242 cam.3.42 posi.12.55@109,4100 lbs...SOLD....
1968 Firebird , 467 , KRE d-ports ,stock type suspension,3100lbs
(1.30 60')(6.08 1/8)(113.43)different runs 9.59 @140.71 on E85 all motor
8.97@148.63 on 150 shot
Old 06-16-2007, 10:15 PM
grandville455's Avatar
grandville455 grandville455 is offline
That stuff is thick! thats why I use a can 15 oz of marvel mystery with my rotella also..... Pontiac vitamins
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 06-17-2007, 08:35 PM
Im wondering if something was stuck under the check ball on the oil pump and it dislodged.I cant believe 1 bottle of STP would raise the viscosity that much.
Mark
Old 06-17-2007, 09:02 PM
gtofreek's Avatar
gtofreek gtofreek is offline
It will do exactly that. The oil itself will get very thin when hot. All it takes is .0025 or more bearing clearance and you will have 15 lbs. or less when hot at idle. If it jumps right up to 50-60 lbs. when you give it gas, then I wouldn't worry about it. I would rather run it with 10-15 lbs. at idle than 40 with STP. At least with the oil alone you have plenty of oil flowing through the bearings to keep them cool. STP hinders this ability. If the engine had no bearing knocks, you have no problems other than an engine with worn bearing clearances. The engine could have came from the factory with .002 clearance and with only .00025 wear on each bearing shell will give you .0025 clearance and give you the kind of pressure you speak of. The oil pump is just not turning fast enough to create 60 lbs. This is pretty common.
I agree with Grandville 455 on the Marvel mystery oil. It's great stuff!
You can also try running 20W-50 oil also and pick the pressure up another 5-10 lbs.
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 06-18-2007, 07:54 AM
This is a brand new short block with an eagle stroker kit so the clearances are a little more than stock.Im going to 20-50 next oil change,I just thought the STP would thicken the 15-40 up a little not a lot!
Mark
Old 06-18-2007, 08:41 PM
big head big head is offline
Default oil pressure
My 462 runs 180 degrees, 30 weight oil and has 15 to 17 pounds @ idle,700RPM in drive.as they say,10 pds oil pressure for every 1000 rpm.As long as your pressure rises acordingly under load there is no problem.when I first rebuilt the motor it did hold 20 pds @ idle . but as clearances loosen up some, pressure might drop slightly.my engine has only 1600 miles on rebuild,no worries with 15 pds.. ps I live in florida where temps average 85 to 95 degrees air temp
