Old 02-21-2006, 03:47 PM
napster's Avatar
napster napster is offline
Default !970 formula steering wheel ?
Are the spokes on the formula wheel painted? If it is what type of paint - Flat or Gloss?
Thanks in advance,
Nap
Old 02-21-2006, 08:38 PM
TJH TJH is offline
It depends. Some were painted, and a lot more were anodized. The spoke material is, I believe, what determines the finish. If aluminum, it was anodized. If steel, then it would be painted with a rough textured semi-flat black. The texture actually ends up looking like extremely bad, dry overspray, but that's what was on those wheels that were painted.
By the way- the majority of these wheels were of the aluminum/anodized variety.
Old 02-21-2006, 11:43 PM
link09 link09 is offline
Send a message via AIM to link09
Heres a quick pick if it helps!!!
7T455HO
Old 02-22-2006, 11:30 AM
TJH TJH is offline
That looks like an anodized aluminum Formula wheel. Only the aluminum were available in colors other than black (although, every Formula wheel that I've ever seen on A-bodies WAS black).
Reproducing that silver finish will be extremely difficult. The only way that I know to do it, is to strip the wheel of all foam, and re-anodize it. Then, you would need to re-cover the rim, using leather and padding to replicate the molded foam. Painting will not produce anywhere near the correct finish (unless someone has used one of the new translucent anodize-look paints with success).
I'd research to be sure that your wheel didn't actualy come from a Firebird. If the silver color is, in fact, corrrect, getting a new molded reproduction wheel (with the thicker style rim cross-section) may be the best option.
Old 02-22-2006, 11:32 AM
TJH TJH is offline
By the way, even the aluminum-centered wheels that I've seen on A-bodies were anodized. They were just anodized in black, instead of silver (or gold, in some F-bodies).
Old 02-23-2006, 04:03 PM
4SLASH6's Avatar
4SLASH6 4SLASH6 is offline
napster, if you are looking for more input on this subject you may want to send an e-mail to DENNIS W. @ denniswro@wowway.com >> I had very sad looking thick grip wheel for my 70 gto restored by him. it is holding up nicely and maybe the best thing going outside of n.o.s. TOM 4/6.
Name:	restored rally #1.jpg
70 GTO 400/4SPD-13.97@102.31
Old 02-23-2006, 05:14 PM
DavesGTO's Avatar
DavesGTO DavesGTO is offline
This wheel has been off the car a long time but I'm sure it is faded but this is how it looks. I do like the darker look slah's has. The horn button on mine is for a '70 - mid '71 I believe. The button on yours is mid '71 -72. I'm putting this wheel on a '72 so if you want to work something out?.....................
