Old 01-26-2002, 10:37 PM
Keith Vrabec's Avatar
Keith Vrabec Keith Vrabec is offline
Do all SD heads have the 6 H as well as the 16 on them? Does the LS 1 intake fit D port heads? Do headers fit SD heads? Need some advice about a car I'm (potentially) buying. The engine also has a valley pan with pcv and standard oil cap. Do D port heads fit on SD block?
Anybody else have an original SD car for sale?
Thanks, Keith
Thanks, Keith
Old 01-26-2002, 11:37 PM
-NO
-YES
-YES
-Original SD oil caps are nearly impossible to find [img]/infopop/emoticons/icon_frown.gif[/img]
-YES
-Engines yes, cars no.
Keith, no offense, I've come to a realization...
I type too much info on the posts, got to get back to work... [img]/infopop/emoticons/icon_wink.gif[/img]
Old 01-27-2002, 07:26 AM
Thank you for the info. Seems like to oil cap might have been lost, and valley pan converted to pcv type. Might have to wait on this one...Seems like too many little things wrong with it.
KV
Old 02-01-2002, 06:31 PM
David Holmberg's Avatar
Keith, it all depends on the price. If the original body (X code), motor and trans are there most everything else can be found.
OPH, Do you remember a Blue/ White loaded 74 SD out of Arkansas a few years ago? The Orig owner took the SD motor and tranny out and swapped it with his new 79 403 TA?
Old 02-06-2002, 10:59 AM
David,
I have never seen that particular SD car. Do hope the owner put the engine back in his '74
