EFI Tech All things EFI and making classics modern!
Old 01-14-2022, 02:11 AM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Default 1" Intake Spacer Dyno Results, 461, EFI, Torker 2 & High Ports
Just spent a ton of money on a new engine, mods and tuning so here's some data since I'm not a track guy, no secrets here. Hahaha
Combo is in my signature, dyno pulls about 2 weeks apart (no miles on the car since last pull).
Mustang Dyno (loaded)
Auto TH400 with new PTC 10"
Calculations are around 20% loss on the conservative side.
Engine = 461, 32 degrees, 12.8 AF/R, E55
No spacer................................... = 442whp/424wtq
1" aluminum Jegs spacer = 468whp/446wtq
https://www.jegs.com/i/JEGS/555/15451/10002/-1
Gain = 26whp and 22wtq
With the 20% loss that's 31hp and 26tq at the engine.
This seems like a lot for a 1" spacer.
I like how you see it early on in the graph and stays up power the whole way.
Others mentioned gaining 2mph and .2 at the track, that seems at least what my combo would gain if not 3mph and .3.
Conclusion, the Torker 2, even ported, is restricting the high port heads. Wish I would've gone Super Victor port matched at the start as I'd probably see another 20+hp.
If curious, 32 timing vs 35 degrees only gained 4whp, that's really surprising IMO. The cars not really responding to timing like I've heard others say.
So for $100 at Jegs, totally worth it on this combo.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct at 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump
The Following User Says Thank You to GOAT8U2 For This Useful Post:
Old 01-14-2022, 06:56 AM
steve25 steve25 is online now
It's not even so much about the ported Torker restricting air flow it's also about the port area neckng down in size from the head flange into the Intake runner.
In the least to maintain a nice wide smooothly rising power band the the whole lenght of the Intake tract from let's say the push rod area up to the meeting point of the plenum and a runner should be the same size overall, and ideally this runner area should expand at a minimum 1% per inch of lenght.
Note that curves in runners act like a reduction in port area.
Old 01-14-2022, 11:14 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Yes the big turns in the runners are fairly narrow and it takes a lot of grinding to keep the head port size up into the intake.
Skip Fix
Old 01-14-2022, 02:15 PM
Formulajones's Avatar
That's awesome for so little money. I'm not overly surprised, I've always said, if you have the hood clearance, spacers are worth playing with on any intake manifold. Gains can be a little, or sometimes a lot.
Dad's engine gained 20 or 22 hp, and that was on a big Victor intake after Tony had extensively ported it. I expected maybe 10 on that intake after all the work.
Increasing the plenum volume by moving the carb further away from the intake floor always seems to help things.
https://youtu.be/XqEydRRRwqE
Old 01-14-2022, 06:13 PM
mchell's Avatar
mchell mchell is offline
“ If curious, 32 timing vs 35 degrees only gained 4whp, that's really surprising IMO. The cars not really responding to timing like I've heard others say. ”
Mine have been similar….timing yielded surprisingly little gains between 28-36 degree’s……that was with aluminum d ports
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
The Following User Says Thank You to mchell For This Useful Post:
Old 01-14-2022, 06:15 PM
Dragncar Dragncar is offline
Nice gain.
But, its now 100$ for a plain open 4150 spacer ?
Old 01-14-2022, 06:45 PM
GOAT8U2's Avatar
The scary part is after spending what I have, to gain 31hp for $100 piece of square aluminum, dyno pull time and the shop to swap on the dyno was the deal of a century. LOL
The real kicker, moving from the 4" air cleaner to the 3" had lost some initial power vs the first dyno session on the same combo. I'm thinking of boxing in the sides of the air cleaner like this video shows added power. I'd like to add the velocity stack but there's no room.
https://www.dailymotion.com/video/x693421
Old 01-14-2022, 06:51 PM
Nice gain.
The aluminum stuff is more expensive. You can still find 1" open spacers out of phenolic for $20-$30 and they'll do the same thing while at the same time transferring less heat to the carb too.
Old 01-15-2022, 10:07 AM
i82much's Avatar
i82much i82much is offline
that’s a pretty nice billet spacer. for the walmart crowd like myself ...
https://www.holley.com/products/fuel...ers/parts/6005
Old 01-15-2022, 10:58 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Are the cylinder heads as cast?
Old 01-15-2022, 02:27 PM
GOAT8U2's Avatar
Oh damn, that Holley one is way cheaper and looks like it came with the longer bolts.
As cast High Port Heads
I figured with my combo 600hp was tops for what I wanted on a Convertible. I'm close but its clear now, Super Victor EFI ported was what I would've gone back in time to do to get a closer potential from the as cast heads. I spent hundreds on just getting the T2 to fit (thread on this) but at least this simple mod really woke up the car.
Old 01-15-2022, 04:23 PM
MidnightAuto's Avatar
MidnightAuto MidnightAuto is offline
thanks for this info. has anyone tried adding 1 inch spacers on a tripower? I've got good heads and a ported factory intake, wondering if spacers might give me a little bump.
