1968-69 GTO/Lemans Parts
1968 Hurst Dual Gate Shifter Restored with shifter cable and wiring harness $525.00
1968 Rear bumper brackets $100.00 1968 GTO Passenger door Glass with lower frame and bracket $100.00 1968-69 Lemans front bumper brackets $75.00 1968 Lemans front bumper black plastic insert $25.00 1968 Lemans front bumper grill brackets $25.00 1968-69 power brake booster $50.00 1968-72 GTO/Lemans lower main duct and vents $200.00 1968-72 Intermediate steering shafts $50.00 1968-72 Rear Windshields $80.00 1968-72 Coils $25.00 1964-79 Oil Filter housings $100.00 each 1968-72 front lower window reveal molding $60.00 1968-72 rear front upper fender chrome moldings $30.00 pr. 1968-71 Throttle cable $45.00 1965-78 Turbo 400 Transmission oil pans $50.00 1968-72 NOS FRONT WINDSHIELD UPPER STAINLESS MOLDING $175.00 1968-72 NOS PASSENGER SIDE FRONT WINDSHIELD STAINLESS MOLDING $100.00 1968-72 door vents pr. $20.00 1968-72 positive battery to starter heat shield tube, 1968-72 1/4 window glass chrome trim moldings $30.00 pr. 1968-72 window regulators set of 4 $150.00 1968-72 brake pedal assembly $125.00 1968-72 emergency brake pedal and bracket $75.00 1968-72 rear license plate bracket and holder $35.00, 1968-72 front armrest bases parchment, black $25.00pr, 1968-72 door & 1/4 glass regulators $50.00 1968-72 water thermostat housings $20.00 , 1968-72 door hinges $50.00 1968-72 points distributors $80.00 1968-72 blower motors $25.00 1968-72 a/c inner boxes $150.00, 1968-72 headliner bows $50.00 set 1969 GTO CARB still in DELCO BOX $850.00 1969 Water pump Date Code is Jan of 69 $50.00 with divider plate 1969-72 AM RADIO WORKS $200.00 1969-75 Harmonic balancer $50.00 11 Bolt Timing Cover $110.00 11 Bolt Timing Cover withy divider plate and pump $150.00 Full length windage trays 80.00 1968-72 Show Quality Front Window Stainless Moldings, Professionally Polished $300.00 NOS A/C Delco PVC $10.00, NOS PULLEY 481040 still in GM BOX $100.00 NOS A/C Delco oil Filters PF 24 $11.00 each 1969-72 Goldenrod/Tan steering wheel crack free $125.00 1969-72 ratchet auto shifters $130.00 Fuel escentrics $35.00 1969-72 harmonic balancer off low mileage car $50.00, flexplates $35.00 1969-72 Standard Gauge & Speedometer cluster $65.00 1968-72 radio rear support bracket $25.00 1968-72 Tag light & bracket $15.00 Distributors 1148 Feb13,70, 1253 Jun 26,68, 2007 Nov 28,69, 2189 Apr 24,72, 2513 Nov 15,73 all distributors $80.00 used pulleys 481040XT water pump pulley, 481038YB crank pulley, 480507 crank pulley, 8inch 2 grove water pump pulley, 480509 TCS Switch $75.00 NON A/C HEATER HOSE BRACKET $25.00 Pontiac oil pan $100.00 new points and condensers __________________ Timmy Mallory Email me at temallory@msn.com
Timmy Mallory |
What shape are the parchment armrest bases in? 68-72
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '69 LeMans Vert, 350, #47 heads: work in progress |
Interested in the '68-'72 rear license plate bracket and holder. PM sent.
Greg Reid Palmetto, Georgia |
Hi do you still have the timing cover? If so would you send me some pics to see what kind of shape its in? I don't need the divider plate. You can also text them if you prefer.
PM also sent Thank you!
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot 1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @164 3500+lbs 10.5W's SOLD! 1964 421 GP-Sold 6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold |
Oil pan
What year is the oil pan
Anyone else hear back from the OP? I didn't.
I never did, found what I needed on Ebay
Greg I received no response from OP.
He has not posted since the above ad.
Does anyone know this gent in real life? Maybe ask in the Lobby. |
That post was an awful lot of work to type up for nothing so I would think there's a good reason he's not responding or posting any more.
I bought parts from him when he lived in Maryland. He lived about 30 minutes from me. Nice guy and easy to deal with. I've bought a few times from him in the past with him living in Florida, but its been about a year or so ago. Try his email.
You might be on to something there. I just noticed that the last thing in his ad is "email me". Maybe he doesn't check here.
EDIT I just sent him an email so we'll see what develops
Greg Reid Palmetto, Georgia Last edited by Greg Reid; 11-21-2023 at 09:17 PM. |
Any response to his email?
Yes, he did respond to me through email.
