Old 08-21-2021, 08:30 PM
lucky1 lucky1 is offline
Default Checking fuel pressure with mechanical pump.
Do you check the pressure at idle or at higher rpm’s ?
Old 08-21-2021, 08:36 PM
Joe's Garage Joe's Garage is offline
Default BOTH at idle and at 2k+ RPMs.
Verify that is is correct at idle and that is doesn't change when at higher RPMs.
You do NOT want to see cavitation - that's where the needle flutters excessively, rather than coming up to the factory pressure and staying there.
We've seen some mechanical pumps' pressure drop off when revved up and others go too high.
Good luck!
Old 08-22-2021, 06:35 AM
steve25 steve25 is offline
Even at slow driving speeds I once found out what the minimum fuel pressure is for a Q-jet .
At 3 psi the motor would idle fine and on level ground with light throttle openings you could do between 25 to 30 mph in a 3700 lb car before it would buck/ sputter and have no response to the throttle.
At this point in time the car was fitted with a big Holley can type filter so pressure loss was likely minimal.
Old 08-22-2021, 10:54 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Set it at idle and then check it at all rpms. Best to have one you can see inside the car, obviously.
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
Old 08-22-2021, 12:11 PM
What kind of fitting is being used? tough to put on a QJet with steel fuel line.
Bill Nye.
Old 08-22-2021, 12:55 PM
It is tuff with a steel line because unless you want to splice in a short length of hose out of the pump all you can do is loosen the line so it dangles out at the pump end.
Old 08-22-2021, 02:04 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Or just get some extra steel line to cut a section out for some rubber while you check the pump's pressure.
Skip Fix
Old 08-22-2021, 11:23 PM
70GS455 70GS455 is offline
If you are wondering whether or not it can supply adequate fuel volume for the hp you are making, you check pressure at WOT in the upper rpms.
Sent from my SM-G991U using Tapatalk
Old 08-23-2021, 08:22 AM
Torquewar's Avatar
Torquewar Torquewar is offline
As stated need to test at all rpm and loads . Many posts over the yrs about running out of fuel etc car nosing over at higher speeds. I made a steel test line with a tee so I could attach a hose with a gauge. Now have AN line with a fitting but same concept. Ran it up to the cowl zip tied it to the wiper arm . I ran the car hard and verified psi at all speeds etc. It’s not pretty but safe. A friend just picked it up couple days ago. Nice diagnostic tool.
Old 08-23-2021, 09:25 AM
android 211 android 211 is offline
My GTO (mild 455 with headers, Q-Jet) noses over or rather flattens out at top of 1st gear, shifting at 4800. It has stock type fuel pump. (whatever a 69 automatic GTO was supposed to have). Other wise runs fine. Is there some volume test that can be run? Say I run a rubber line to the carb with gas and then start the car, how much fuel is supposed to come out of the pump in how much time?
I have a buddy with a very mild 350 '73 Corvette, he says it runs well except it flattens out at 3000. After reading other posts about junk fuel pumps here, I wonder if both of us have bad fuel pumps. I have the Carter pump recommended here but I'll have to cut my steel fuel line and splice with some rubber hose to use it, plus block the return line. The Carter pump doesn't use one.
