Al Knoch Seat Foam
I ordered a set of 70 cushions a couple months back only to find that the internal wire frame was set too deep to be able to hog ring the seat covers to them. I worked with A.K. to have this issue corrected and it should no longer be a problem for anyone buying them in the future. I don't understand how no one brought this up prior. The cushions are nice. The only other problem is that there is too much foam on the tops of the seat backs and some trimming will have to be done. You'll also have to add extra cotton batting to fill the covers out.
The Legendary covers have an issue with the hole for the seat latch being located too far inboard. You can either bring this up before you order, or relocate the backing ring and then cut the hole since it isn't seen when installed (leaves stitch holes).
I'll post pics when they're complete.
