#41
#42
Previous page OP posted he has already gotten a set of 6X-4 for ($100) and has since already had a shop rebuild them ($300)...
Thats not a bad deal on the 5C -4 heads though. If you were local I would buy them
63 Catalina coupe 455 budget drag car 11's 1/4 , 7.4 1/8th 66 Star Chief Executive 57k mile 69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2007 Hummer H3 3.7 liter turd 2019 Chevy Spark petrol car 38 mpg |
#43
The #64 is nothing special from a performance standpoint, there are quite a few D-port heads with nicer ports from the factory than this one. |
#44
The point I was making for D port heads the # 64 are the top performance head out of the factory. If you want high compression this is the top . That is the point I am trying to make. You do not have to shave the heads for high compression and the valve size is as big as Pontiac made in a production head. So if you want heads that are a lower cost you can buy a set of #13 1970 heads 2.11 intake 1.77 exhaust give you about 9.5 comp on a 455 because they are 400 heads and are available.
#45
#46
ONE of the main differences between the 64 and the 15 is the 15 head has the smaller exhaust valve (1.66). Open that up to a 1.77 and then they nearly identical, with the 15's being much cheaper to start out with.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
#47
Yep and since we are working with 40-50 year old heads we usually need to buy valves anyway...
#48
It's all bolted together with a '70 PR code TH400 trans behind it . Can't wait to feel the torque.
#49
another difference with the 15 head, is they use press in not screw in studs, and are a lot cheaper than 64 heads.
several guys updating to screw in and using on their 400 builds.
FREEDOM ISN'T FREE BUT WORTH FIGHTING FOR |
#50
I have a 1976 Trans Am that I purchased from a guy its has a 455 with heads stamped 62 on the castings the compression I was told is 13:1 with a dome set of pistons I want to actually get the compression down to around 10:1 but I thought #62 heads were for a 400. 2:11 X 1:77's also wouldn't 13:1 be hard on a 455 with it's rod angle
#51
The 13:1 compression is only hard on your wallet because of the need for expensive straight race gas, the 455 rod angle is really a non-issue as far as high compression ratios are concerned. You'll need a 20cc dished piston to get compression down close to 10:1 if you're intent on keeping the #62 heads.
#52
with a 455 that 4.56 gear is worthless on the street, even on the track racers need good slicks to control the torque.
street, I bet you would be a lot happier with 3.42-3.55 max. if you have some sticky tires and the right cam and heads to make power at a higher RPM, maybe 3.73-3.90 max, but I would consider those bracket racing type gears. I ran 3.08s in my 73 455 Trans Am, it ran real well, but think it would have been about perfect with 3.23-3.42 gears. depending how yours is set up, rpm range it makes power, what gears it will run best with. mine was; 455,+.030 flat top TRW pistons, zero deck block, small chamber 4X heads( approx. 9.0-1 compression, summit 2802 cam. ram air manifolds, performer intake, 1800 stall converter, 3.08 posi, 275x15x60 on ralleyII rims.
#54
Where do you see that price?
I see you can buy BARE Edelbrock heads for about that. Assembled heads are over $2000.00/pr as best I can tell. http://www.jegs.com/p/Edelbrock/Edel...46694/10002/-1 Quote:
-- James Work '67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake." '75 Formula 400 - Daily Driver - Running with my Home Built 455 and TH400 Details here: http://forums.maxperformanceinc.com/...d.php?t=588372 |
#55
A set of new E-heads at Lane Automotive which is the speed shop I deal with , you can get a new complete set for right at $ 1750.00 plus tax. The set I have right now cost me $ 1550.00 a few years back but I just was there about 3 weeks ago & they are at the $ 1750.00 price for them. Those are the 87 CC heads which on my 462 gave me right at 9.4 to 1 comp. It runs great & pushs my 73 4 spd. 373. rear car to 11.72 at 119 mph. The 462 fro mine has SRP forged pistons with eagle rods & a Crane RAIV blueprint cam with an Performer RPM intake with a Q-jet. All I have to burn is cheap 87 grade gas & runs that great without a ping or pop. I love them , but to I think your forgetting about the 69 RA III heads which are the # 48's . You can use pistons like I did on my last engine . I used some Jahns free floaters that had a 10cc dish with the 48's & all I ran was again 87 without any ping & it ran very good that way. The 48's are a very good flowing head to. As good as the # 64's for 70. The only diff. was the 48's were 65 cc heads & the 64's were 62 cc heads. Thats what gave it the bigger push on the 428 to get the comp up & be able to push the HP to 370 instead of the 366 for the 48's. Flow rate was the same. You have to remember that the extra HP came from the extra cubes fro the 428 & the little longer stroke. If you put the 64's back on a 400 it would be the 366 HP on the 400 just like the 13's were. It's like the old saying ,,, there no replacement for displacement. Bigger is better. Put the 64's on a 455 & you will get about 375 HP if all the parts are the same. Again displacement.
