Old 02-23-2019, 12:07 AM
JUDGEMAN70 JUDGEMAN70 is offline
Default 69 GTO engine unit number stamping
Has anyone seen an engine unit number as sloppy as this one? Framington Mass. built car. Restamp?
Old 02-23-2019, 01:38 AM
Ram4king's Avatar
Ram4king Ram4king is offline
That's pathetic!
Old 02-23-2019, 05:28 AM
dataway's Avatar
dataway dataway is offline
My guess is a forgery would look way better.
Although it does almost look like there are grinding marks ... but why forge the unit number ... the code is the important part.
Old 02-23-2019, 09:32 AM
rustedgoat rustedgoat is offline
Looks like first digit "1" is upside down. I know its the engine unit # but do those numbers match the last digits of the VIN?
"Honestly the car will only be there for a few weeks, OK maybe a month at the most"
Old 02-23-2019, 11:52 AM
1969 Ram Air 1969 Ram Air is offline
Lack of gang stamping for sure. I'd like to see the partial VIN stamp.
69 GTO Judge, Liberty Blue/Parchment, RA3, 4-speed
69 GTO, Verdoro Green, Green, 400, 4-speed
69 Firebird 400, Starlight Black/Black, RA3, 4-speed, 611 RA Inlet
Old 02-23-2019, 12:25 PM
muscle_collector's Avatar
you will see the sloppy work on the early SD engines and the ra 5 engines but for a WT ????
Old 02-23-2019, 01:04 PM
dataway's Avatar
The engine unit numbers have to do with the order it was produced in the engine plant.
The VIN number is stamped lower down on the block. Same side as the unit number.
Old 02-24-2019, 08:27 PM
Simple Man's Avatar
Friday build.....
be a simple...kinda man.
Old 02-24-2019, 08:32 PM
indymanjoe's Avatar
Or a long weekend build on a monday morning..
Old 02-24-2019, 08:39 PM
That looks very obviously ground down to me. The sanding marks are nearly visible even before you enlarge the photo!
Old 02-25-2019, 01:46 AM
Was wondering if they just stamped there, not knowing it was in another location.
Old 02-25-2019, 04:03 AM
dataway's Avatar
Greg, since the numbers are so badly stamped .... wonder if the factory ground off the "first try" because they were even worse (new guy on the line?), obviously they don't want to trash a block because of the numbers.
Looks ground to me too ... but why forge a unit number, it's pretty much meaningless.
Photo below showing top yellow circle, UNIT number and block letter code.
Lower yellow circle, location of VIN stamp.
Old 02-25-2019, 04:12 AM
dataway's Avatar
Also ... that unit number and code looks very crisp.
If the engine is supposed to be original to the car ... boy I'd want to see the VIN stamp for sure.
( I'm curious ... is it possible to mill .030" off the engine front surface of a Pontiac V8 without causing any unusual problems or obvious visual cues?)
Old 02-25-2019, 09:39 PM
grandam1979 grandam1979 is offline
How’s this?
Old 02-26-2019, 02:23 AM
dataway's Avatar
Well, the font looks a bit different. I have no idea if fonts were consistent from plant to plant.
Old 02-26-2019, 03:10 AM
I can't imagine why unless it was someone that thought that was where the partial VIN goes. Back when I bought my '68 (from a Chevy guy) he told me that the engine VIN did not match the car so a non matching engine. When I got it, I found that it did, in fact, match...he was looking at the EUN.
Old 02-26-2019, 07:28 AM
DANTIP DANTIP is offline
This one is pretty bad.
Name:	Screen Shot 2019-02-26 at 6.26.40 AM.jpg
Old 02-26-2019, 02:44 PM
dataway's Avatar
Hehehe .. yep, if I found a block where the unit number matched the VIN, I would be very surprised. I hope you haggled the guy down because it had a crappy non-original engine
When it comes to RA IV stuff ... jeez, who knows, not me, I've never even seen one. I don't even know if they came off the regular engine line.
Old 02-26-2019, 03:27 PM
The font of the two letter engine code & the font of the assembly number (Eun, for all the "Eunics") was the same, as both were stamped at the Pontiac MI engine plant. Only the partial VIN was stamped at assembly plants.
Am not sold on the font of the stamping of the 0's on the above WY coded block. To make a further judgement, would will need to examine a good amt of original '69 Pontiac blocks, I have a few '69 428's & can examine in the next month several '69 350's & 400's.
Old 02-26-2019, 03:59 PM
Maybe someone found a WT block for the car and stamped the last six numbers of the VIN there because he thought that the EUN was the VIN. I wouldn't be surprised if the VIN on that car ends with 165749. My experience is that while assembly plant VIN stamps down below vary greatly from plant to plant and even car to car from the same plant. But the EUN and engine code look all the same regardless of assembly plant. Makes sense since they were probably all stamped by a machine as part of the machining process at the home plant foundry.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
