Old 06-04-2021, 09:00 PM
Default CP piston install question?
Ok I bought a set of CP pistons a few years ago and I知 now assembling the engine I got them for. Problem being they are L and R short skirt pistons but with double valve relief. So when I look at pistons from bottom you can see one corner is thicker than the others. I知 assuming the thicker area would be under exhaust valve or am I totally wrong?
ID:	567751   Click image for larger version
ID:	567752   Click image for larger version
Old 06-04-2021, 09:55 PM
It is my understanding from talking to Barry Calvert (President of CP) and his brother "Snake" at the PRI shows that CP Pistons were "Non-Directional" meaning the piston does not care which set of valve reliefs you install upward.
No direction arrow on which way should face the front of the engine. But that was some years ago, just like the age of your pistons.
Tom V. .
Old 06-04-2021, 10:33 PM
Can you see in the picture where the one corner is thicker than the others?
Old 06-05-2021, 01:02 AM
Jay S's Avatar
Jay S Jay S is offline
I would guess the thicker corner would be positioned to the trust side. Unless it is just because the pin is offset, could position it either way depending on the use.
Old 06-05-2021, 08:54 AM
Non-directional means no offset like a factory piston. See post #2.
If you have a non directional piston then both sides of the piston can be the same contour/thickness and no reason to add more weight to on side of a piston to make it thicker and "stronger" on the thrust side.
Old 06-05-2021, 01:01 PM
Jay S's Avatar
The shorter thick skirt is hard to see in the picture. Pin offset I thought I noticed was likely and optical illusion.
Main point I was trying to make was is if one side of the skirt looks like it has more support or skirt area, it was likely designed to be positioned so that the larger skirt area was to be positioned to the major thrust side of the cylinder. If the thicker looking side is thicker looking because they machined it shorter and the piston is symmetrical like Tom said, then it probably belongs on the minor thrust sided. Doesn’t sound to me like the pistons are non directional if the skirts are not identical. Fwiw
Old 06-05-2021, 02:04 PM
The top down shot of those pistons ( if taken close to being centered) really looks to me like the pistons have valve notches for both early and late heads due to the notch off set.
You set them up on the rods for the heads you are running (since there’s no Wrist pin off set )that being 20 or 14 degree, very efficient and clever by CP!
Old 06-05-2021, 02:11 PM
You set them up on the rods for the heads you are running (since there痴 no Wrist pin off set )that being 20 or 14 degree, very efficient and clever by CP!
Agree. Very clever.
Old 06-05-2021, 02:18 PM
Scott Stoneburg's Avatar
If the OP is talking about the under side of the valve relief, then I would think the thicker area would be for the intake valve. Manufacturer leaving more material for the intake valve relief due to the valve being larger and the relief for the intake valve usually being a deeper cut in thw piston.
Old 06-05-2021, 02:40 PM
Yes it is the underside that is thicker the skirts are the same on each piston that痴 what I didn稚 understand because they are R and L pistons for each bank. That made think if the thick area was for heat distribution from exhaust side.One thing I learned on this build is don稚 build a shortblock around used pistons. LAL thanks for the replies
Old 06-05-2021, 03:15 PM
If the Op will confirm that the valve notches are cut for both early and late valve inclination heads then whatever difference there happens to be in thickness of that corner material is a 100% moot point!
Old 06-05-2021, 07:30 PM
Valve notches look to be the same both sides all are .168-.170 deep. the thick area I知 talking about is mirrored from the L to R pistons. See picture.
ID:	567814   Click image for larger version
Old 06-05-2021, 10:01 PM
The other picture was an optical illusion, No 389/421 valve reliefs on those CP pistons.
Thanks for the better pictures.
Old 06-06-2021, 06:11 AM
Yup, far different then in that first photo!
Old 06-08-2021, 06:26 PM
Tom V. .
I talked to a CP tech today and you are correct this piston can be mounted either way. They said don稚 worry about the thick area. Thanks for the replies
Old 06-08-2021, 06:51 PM
GLAD IT STILL APPLIES TODAY WITH THEIR STUFF.
I talked to Barry & Snake at every PRI show held in Florida back in the days when Bob, Frank, I, the Butlers, and the guy who used to make the cast iron round port manifolds worked that show every year. Promoting Pontiac HP New Parts.
Old 06-20-2021, 07:31 PM
Anyone have a good guess of the cc on the pistons?? I知 thinking 16cc I never did check.
Old 06-20-2021, 07:37 PM
AG's Avatar
AG AG is offline
Looks like a TRW stock replacement valve relief which would be about 6.7 cc.
