Old 06-16-2021, 08:28 PM
chuckies76ta's Avatar
Default Transmission Shield
Hi: When is a Tranny shield needed? Just had the Firebird out and ran a 10:30 at 132 mph.
I installed a JW bellhousing on the TH400 this year so Flexplate area is done.
Charles
Old 06-17-2021, 01:35 PM
leeklm's Avatar
leeklm leeklm is offline
Pretty sure a tranny blanket is needed at the same time a 6pt roll bar is needed. 11.5 ET or something close to that
Sent from my SM-G965U using Tapatalk
Old 06-17-2021, 02:19 PM
firechicken's Avatar
firechicken firechicken is offline
Yes, trans shield required at 11.49 et same as a roll bar, harness and fire jacket.
More stuff required at 9.99
Old 06-17-2021, 05:21 PM
Ok guys, Thanks I was under the impression it was needed at 10.99 to 9.99.
Old 06-17-2021, 05:44 PM
AG's Avatar
AG AG is offline
I use a DJ Safety TH400 trans blanket, nice piece.
Old 06-17-2021, 05:48 PM
Thanks AG, I'll check it out. Dam just ordered a starter from these guys a month ago.. Could have bought it then...
Old 06-18-2021, 07:24 AM
grandville455's Avatar
U need a trans blanket at 10.99 I believe
Darby
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 06-18-2021, 07:45 AM
Ya that's pretty much what I have found out now. Have one on order now. Thanks for the info Darby.
Old 06-18-2021, 10:36 AM
Old Goat Racer's Avatar
SFI SPECIFICATIONS
Mandatory at ET (or quicker) Item SFI Spec
13.99 Drive shaft loop (slicks)
13.99 Helmet (Snell K98+)
13.49 5-pt harness (convertible) 16.1
13.49 Approved rollbar (convertible)
13.49 (IHRA) Drive shaft loop (slicks)
11.49 Drive shaft loop (street tires)
11.49 Approved flywheel & clutch (manual transmission) 1.1, 1.2
11.49 Approved protective jacket 3.2A/1
11.49 Approved roll bar for all vehicles
11.49 Approved 5-pt harness 16.1
11.49 Approved flywheel shield (manual transmission) 6.1, 6.2
11.49 (IHRA) Approved mounted fire extinguisher
11.49 (IHRA) Approved flywheel shield (automatic transmission) 4.1
10.99* Approved roll cage (convertible)
10.99 Approved harmonic balancer 18.1
10.99 Approved aftermarket axles
10.99* Approved transmission shield (automatic transmission) 4.1
10.99 (IHRA) Competition License* Class D
9.99 Approved flexplate & shield (automatic transmission) 29.1, 30.1
9.99 Approved roll cage & window net* 27.1
9.99 Master cutoff switch
9.99 Competition License Class 4, Cat. C
9.99 Chassis Certification
9.99 Approved jacket/pants/neck collar/gloves* 3.2A/5, 3.3, 3.3/1
9.00 (IHRA) Roll cage & window net
8.99 (IHRA) Competition License Class C
8.49 On-board fire system
8.49 to 7.50 Chassis certification 25.4/25.5 (3600#)
7.99 (IHRA) Competition license Class B
7.49 & quicker Chassis certification 25.1E (2800#)
7.50 & slower Chassis certification 25.2 (3200#)
7.49 Competition license Class 3, Cat. C
IHRA Pro Stock Competition license Class A
150mph + Parachute required
200 mph + Head & Neck Restraint required
* Also required for 135 MPH or faster
Everybody knows somthin.
Nobody knows everything !
Old 06-18-2021, 10:39 AM
ponjohn's Avatar
ponjohn ponjohn is offline
Oh crap - really.
And a trans shield meaning a blanket or shield over the case?
Old 06-18-2021, 11:48 AM
https://www.csr-performance.com/shop.../super-shields
Old 06-18-2021, 04:14 PM
Thanks Old Goat Racer for taking the time to post that info..
Charles
Old 06-18-2021, 04:16 PM
Originally Posted by Skip Fix View Post
Thanks for the link Skip. It's too bad they don't make just the trans shield without the bell housing part. I've seen it in metal.
Old 06-18-2021, 04:21 PM
Originally Posted by ponjohn View Post
Oh crap - really.
Yes. From what what my understanding is now, you have to have a SFI Spec 30.1 bellhousing or a shield over the stock bellhousing. and a SFI spec 4.1 tranny blanket or Tranny shield. You can buy in two piece configuration or as a complete unit that bolts to belt housing.
Old 06-18-2021, 04:25 PM
ponjohn's Avatar
Generally do they fit in a stock trans tunnel?
Old 06-18-2021, 04:29 PM
I don't know. I installed a JW bellhousing when I built our TH400, so that takes care of the bellhouing area. J.W. bellhousing is spec 30.1 I just need a tranny shield. I ordered a blanket from Good Vibrations.
Old 06-18-2021, 04:43 PM
SNUG, but yes. In my 70 GTO clone
Old 06-18-2021, 06:10 PM
CSR sheild fits in my 77 ta
Old 06-19-2021, 01:36 PM
CSR fits my 79 Camaro IA fine. The hard part is getting those top bolts in ! Be nice if you could use the JB bellhousing and then section that part off the CSR shield for just the tight tranny part.
I did have to grind down some ribs on the case for it to fit.
So how many of you all have had tech check for one? And if they checked date on it?
Old 06-19-2021, 02:12 PM
They always checked that I had one but never checked the date thank goodness. Pretty tough to read the sticker, you can just barely see it down in the tunnel.
Ears needed ground off my T400 for the shield to fit.
