Old 09-12-2002, 03:12 PM
79TA455's Avatar
79TA455 79TA455 is offline
Just have a quick question. My 76 455 is leaking where the oil filter goes on so I want to replace this peice.
1.What is it that peice called?
2. Can it be taken off and replaced without removing the oil pan?
79TA455's Avatar
Old 09-12-2002, 03:25 PM
Txbobcat Txbobcat is offline
No problem. Oil filter housing I believe is correct terminology. 2 bolts and it is off gasket behind it. Usually they leak because oil filter gasket was left behind with last oil change. If leaking at block just remove and put some silicone on after cleaning it up then replace.
Old 09-12-2002, 03:27 PM
Wade Congdon's Avatar
Wade Congdon Wade Congdon is offline
What Bobcat said except there are three (3) bolts. Just so you are not confused
Wade Congdon
BOP Engineering
Hi-Performance Specialty Parts for Buick, Olds, and Pontiac
www.bopengineering.com
Old 09-12-2002, 04:39 PM
Robert Williams's Avatar
Robert Williams Robert Williams is offline
Are you sure the filter is not leaking at the o-ring. If you remove the housing from the engine block you will need a gasket to install it. Fel-Pro #13426 or Victor Reinz #B7147 will do it. If you can't find one then let me know and i will mail you one, FREE on me. Let me know if you need help.
"Three may keep a secret, if two are dead"
~ Benjamin Franklin ~
Old 09-13-2002, 12:30 AM
I got a nice used oil filter housing if ya need one got fresh paint and everything [img]tongue.gif[/img]
Mike
Old 09-13-2002, 09:49 AM
79TA455's Avatar
Thanks guys.
The leak is occurring where the filter and housing meet. I have already taken off the filter and cleaned both surfaces. There are no gaskets stuck to it. It is not leaking from the block.
I'm going to try and get the housing and gasket this weekend. I appreciate the offers for the gasket and housing but I am in Canada and it is probably not worth shipping it. [img]tongue.gif[/img] I should have no problem finding what I need here.
Old 09-13-2002, 01:34 PM
critter's Avatar
critter critter is offline
Oil sending unit? The metal piece that the wire plugs into from the wiring harness. These will leak while your housing is just fine.
12.84 @ 106.89 with street radials.
12.63 @ 108.39 on drag radials.
Old 09-13-2002, 02:22 PM
79TA455's Avatar
<font size="2" face="Verdana, Helvetica, sans-serif">Good idea to check that but nope. Not leaking from there. I can actually see the oil resting on top of the filter.
