Old 07-15-2020, 09:32 PM
grd777 grd777 is offline
Default missing some mounting clips for my 72 firebird rear tail light harness
i am mounting my rear tail light harness on my 72 firebird . i have the ones that go on the trunk gutter ,but i think i need something at the ends near the tail lights
Old 07-16-2020, 11:03 AM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
The tail light harness has a couple pinch clips taped on to retain it to the rear bumper side brackets inside the trunk for the side marker lights. Besides those and the four trunk gutter harness clips that is all there is.
Old 07-17-2020, 05:46 AM
i saw that firebird central sells some kind of clip that mounts on one of of the tail light screws
Old 07-17-2020, 10:12 AM
dld's Avatar
dld dld is offline
here is a pic of what i think harness should look like . please comment if incorrect .
hope its helps with this post
ID:	545153   Click image for larger version
ID:	545155   Click image for larger version
Old 07-17-2020, 05:12 PM
Great photos of your trunk. I want to detail mine like yours.
Is the small clip on both sides of the trunk
Are there only two of the black clips or 4
And what is the colour you used for your splatter paint
Old 07-18-2020, 02:02 PM
dld's Avatar
dld dld is offline
one clip on both side attached to bumper reinforcement as mention
4 clips on rear body panel That shielded harness hangs in
splatter done with spray gun after blk/gray epoxy as base. Then cleared with two stage clear with flatterer added as ness.
Old 07-19-2020, 10:45 PM
cdnroundport cdnroundport is offline
Sent you a PM
Old 07-27-2020, 09:46 PM
Held for Ransom's Avatar
My parts bag only had one small clip in it.
So long, farewell.
Old 07-27-2020, 09:58 PM
ok how much
