Old 04-28-2013, 06:58 PM
455Grandville's Avatar
455Grandville 455Grandville is offline
Question Gas tank repair question -
I ran over something in my 4wd Dakota and the gas tank is now leaking slightly at the bottom. It's just a old wood hauler kept on the property and I don't want to put any $$ in it; has anyone tried using JB Weld or A fuel tank repair that NAPA sells with good results ?
Two 1975 455 Grandvilles &
'79 455 Trans Am
‘69 Camaro SS 396/375 (owned since ‘88)
‘22 Toyota Sequoia V8
‘23 Lexus LS500 awd
‘95 Ford F-super duty 4wd 7.3 p-stroke
& countless Jeeps & off road vehicles.
Old 04-28-2013, 07:00 PM
sleepy's Avatar
sleepy sleepy is offline
Plastic or steel tank?
Why is he not suspended?
Old 04-28-2013, 07:06 PM
Steel
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 04-28-2013, 07:12 PM
sleepy's Avatar
JB weld. Drain the tank, Dry the repair area after some breakclean to clean it. apply the JB and let it set up 24 hours. Should last longer than the tank.
Old 04-28-2013, 07:14 PM
Super Duty D's Avatar
Super Duty D Super Duty D is offline
There is an Epoxy type product that you can use, I forgot the manufacture, but you will need to remove the tank to be able to clean and coat the entire inside if it. I think I found out about it on a Motorcycle forum.
It might of been a POR product, IIRC.
SDD
found link; http://www.por15.com/US-STANDARD-TAN...oductinfo/TSG/
and another; http://www.por15.com/FUEL-TANK-REPAI...ductinfo/FTRK/
Old 04-28-2013, 07:25 PM
FrankieT/A's Avatar
I bought this stuff at an auto part store the other day, comes in a clear box, hangs on a hook at the part store. Anyway, it came with a two part epoxy in one envelope, a little piece of sand paper, a piece of what looks like fiberglass roving and an acid brush. You squeeze the envelope containing the two part epoxy causing the two to mix within the pouch. Cut it open with scissors and use the acid brush to apply. I have to say it worked great. I looked for box but the trash went out already. It was $12.00 though. BTW no tank removal, no coating inside, this is done entirely from outside. Stuff cures in mins, work fast!
Old 04-28-2013, 08:50 PM
Sirrotica's Avatar
Sand or wire brush the area around hole, wipe it down. Mix some bondo up with a lot of hardener in it and spread it on a piece of saran wrap or wax paper. Push it in to the hole and hold it until it sets up and your done.
I've fixed them with gas in the tank, of course if it's not running out your chances are better for it to stick. I've done a few and they were still holding when the car went to the scrap yard.
This repair was done out of desperation of 16 YO kids that didn't know if it would work or not, but we damn sure didn't have enough money to have the tank fixed correctly in a radiator shop, and we didn't want all our cruisin gas to run out on the ground, and we were in a hurry too.......................LOL
That was in a 62 Belair bubble top and my buddy drove the car for probably 3 more years and it was holding when it went to the boneyard.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 04-28-2013, 08:56 PM
59safaricat 59safaricat is offline
Bar of ivory soap.
Old 04-28-2013, 09:12 PM
69goatboy's Avatar
69goatboy 69goatboy is offline
I used the POR tank repair stuff with disastrous results. The stuff peeled away in sheets.
I ended up buying a new tank for the goat. I've used POR stuff elsewhere with satisfactory results though.
The joker in the deck keeps sending me his card.
Smiling friendly, he takes me in.
Then breaks my back in a game I can't win.
Old 04-28-2013, 09:27 PM
goatless's Avatar
goatless goatless is offline
I used this stuff as an emergency repair on my Lemans tank several years ago. Had about a 1/4" puncture from an improperly placed tow strap. Got to the track 20 minutes later and refilled the tank. Raced all day with no leaks. Been there 7 years now with no issues so I've left it.
1966 GTO
Old 04-28-2013, 09:46 PM
Bob Dillon's Avatar
Bob Dillon Bob Dillon is offline
Location: Gilroy, California, USA-Garlic Capital of the world!
Thumbs up
Originally Posted by goatless View Post
I used this stuff as an emergency repair on my Leman tank several years ago. Had about a 1/4" puncture from an improperly placed tow strap. Got to the track 20 minutes later and refilled the tank. Raced all day with no leaks. Been there 7 years now with no issues so I've left it.
I was just about to suggest this product. Worked like a charm for me, lasted 3-4 years and was in place when I sold the car.
"Democracy is a beautiful thing, except for that part about letting just any old yokel vote."
~Jack Handey, Deep Thoughts
sleepy's Avatar
Whatever you end up using #1 rule is clean and dry for the repair.
Old 04-28-2013, 11:22 PM
Stuckinda60s Stuckinda60s is offline
Is that the stuff that reacts with the gas? All you have to do is push it in to the hole(s)?
Rich
The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance.
Henry Ward Beecher
"The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher
Old 04-29-2013, 12:17 AM
Dick Boneske's Avatar
JB Weld is the best bet. Forget the rest. Call their 800 number if you want confirmation of whether it's fuel proof.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 04-29-2013, 09:01 AM
This stuff works. I've used it on plow trucks with good results.
Mike
former." --Albert Einstein
- Winston Churchill
Old 05-19-2013, 08:00 PM
Thanks for all the replies
I found this at some small hick store near the cabin and it worked like a charm.
This weekend I beat the the Dakota mercilessly in the woods, no leaks.
'79 455 Trans Am
‘23 Lexus LS500 awd
Old 05-20-2013, 01:40 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Glad you got it fixed.
Just for future reference- JB-Weld (and probably other 2-part epoxies) are gasoline-proof and work well if that area of the tank can be kept dry while it cures. The last time I had a small puncture in the bottom of a tank, I used a sheet metal screw and rubber washer to temporarily close the hole, then patched over screw-and-all with JB-Weld. It still looks great about four years later.
Old 05-21-2013, 12:21 AM
cuz68's Avatar
cuz68 cuz68 is offline
Unhappy
I found the leak on my 97 nissan truck sunday, Droped the tank today it was 3/4 full of gas, My leak was in the back of the tank where the seam is, I dont think it can be fixed with the rust on the seam, I went to a junk yard today thay have one for $50 thay will take it off to day, I hope it will fit and have a good fuel pump in it, My fuel pump has a lot of rust on the top it is the one that came with the truck new.
Cuz68
Old 05-22-2013, 12:31 AM
cuz68's Avatar
Smile
It was hot here today 87 with no wind, We got the tank on Everything is working fine so far, Got the tank for $40
Cuz68
Old 05-22-2013, 12:17 PM
Rack776's Avatar
Rack776 Rack776 is offline
I had used this permatex stuff about 20 years ago, I bought my Bird in 1993, fixed a leak with it and prepped it as well as a 17 year old follows directions, never had an issue with it the repair, I drove the heck out of that car for about 10 years in Eastern PA winter salt and all.
Best stuff on the planet! beats WD-40 and Duct tape on the all time cheap fix list.
JB weld got nothin on this stuff.
Jason Rackawack
1975 455 Trans Am - 1975 Firebird 400
